Date/Time: Tue, 28 May 2024 02:37:22 +0000
showing two volume profiles on DOM
View Count: 2028
[2016-03-16 02:35:56] |
dominikos - Posts: 106 |
I currently use volume profile study on DOM chart. The volume profile is for the current session. I would like to display a second volume profile on the same DOM for a predefined number of sessions, for example, last five. Is it possible to do it? I tried two volume profiles, one aligned to right but I don't see option to specify number of sessions to calculate it for. Ideally, I would like to have volume profile on both sides of the prices. I would appreciate your thoughts on how to accomplish it. Thanks, - Dominik |
[2016-03-16 17:08:14] |
This is supported. How to use the Volume by Price study is documented here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php You need to set the Volume Graph Period Type Input as you require. Refer to the documentation for this Input: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#InputVolumeGraphPeriodType This is definitely not supported: Ideally, I would like to have volume profile on both sides of the prices. I would appreciate your thoughts on how to accomplish it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-16 17:09:11
[2016-03-16 23:38:24] |
I re-read documentation and I'm still unclear how I can configure volume profile study to show me volume profile for the last three trading sessions - including current. I can specify manually start time to be three days ago, but that's the best I can come up with. Am I missing anything?
[2016-03-17 04:09:34] |
Yes we see now that the capability you are looking for is not currently supported. We will see about adding this later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-17 12:47:25] |
Thank you, let me know if you consider it. Manual work around is not bad but it would be nice to have this flexibility on the volume profile.
[2016-03-17 17:04:27] |
We should be able to get this done in the next two months.
[2016-09-09 09:48:57] |
User60591 - Posts: 39 |
Hi, Is it possible to draw second VbP for the last 30 minutes? i.e. I use market profile so It would be good to see a VbP for the last letter or 30 min bar. Also I tryed to draw a second one form US open till close. I was not able to do it, it starts to draw immediately when i set it up. Can you pls help me with that' thnx Date Time Of Last Edit: 2016-09-09 09:49:50
[2016-09-09 17:21:12] |
Yes. You need to set this Input: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#InputVolumeGraphPeriodType To: One Period At End of Fixed Time Length Refer to the documentation for details. If you are also using the TPO Profile Chart study you need to set this input to Yes: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#InputSetAsIndependentVolumeProfileForTPOChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-09 17:21:58
