Date/Time: Tue, 07 May 2024 23:16:10 +0000
ACSIL and Millisecond Timestamps Question
View Count: 3374
[2013-07-03 11:16:53] |
1. When I reference the tick chart from a higher level chart, can I reference the datetime array on the referenced chart? can I reference the ms data of the datetime array? 2. Does the following hold true for all bar chart types (time, volume, tick, range): if the timestamp of the tick bar is greater than or equal to the time stamp of the bar at index "Index", and the timestamp of the tick bar is less than the time stamp of the bar at index+1, then the tick "belongs" to the bar at index "Index". 3. Does the above depend on the datafeed and/or datafeed setting in anyway? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-03 22:57:09] |
The reason for the delay, is we had to do some code review to make sure the millisecond class was working as expected. We also had to prepare a code example. 1. Yes. Here is a complete code example: SCSFExport scsf_MillisecondsExample(SCStudyInterfaceRef sc)
{ if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Milliseconds Example"; sc.AutoLoop = 1; sc.FreeDLL = 0; return; } //When working with milliseconds it is necessary to define variables of type SCDateTimeMS SCDateTimeMS DateTimeMS , DateTimeMSRefChart; // Get the milliseconds for the current bar. Usually this will be 0. This is only an example of how to do it. DateTimeMS = sc.BaseDateTimeIn[sc.Index]; int MilliSecond = DateTimeMS.GetMilliSecond(); //Get the Date-Times from another chart. SCDateTimeArray RefChartDateTime; sc.GetChartDateTimeArray(2, RefChartDateTime ); if(RefChartDateTime.GetArraySize() != 0) { //Get milliseconds for last bar in the other chart being referenced DateTimeMSRefChart = RefChartDateTime[RefChartDateTime.GetArraySize() - 1]; int MilliSecond = DateTimeMSRefChart.GetMilliSecond(); } //Compare the Date-Times from the 2 charts with millisecond precision if(DateTimeMS ==DateTimeMSRefChart) { //There is a match down to the millisecond } } 2. Yes. But to use millisecond precision requires the use of the SCDateTimeMS type. 3. This does depend upon having tick by tick data in the data file. So the Intraday Data Storage Time Unit must be 1 Tick. There can be an issue with historical tick data downloaded from services like IQ Feed but we will solve that. This will be done in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-04 07:59:32
[2013-07-04 07:59:13] |
1. This code example has been updated to compare 2 Date-Time values to see if they match down to the millisecond level. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-29 20:21:10] |
onnb - Posts: 661 |
// Get the milliseconds for the current bar. Usually this will be 0. This is only an example of how to do it. Not sure what is meant by "Usually this will be 0." |
[2013-07-29 22:31:08] |
Updated comment: // Get the milliseconds for the current bar. This will be 0 if the chart bars are based upon a specific time by using the 'Days-Minutes-Seconds' Bar Period Type since the start time for a bar is always evenly aligned to a second based upon the Session Start Time and the time period of the bar. Otherwise, the milliseconds can be obtained for other Bar Period Types.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-29 22:31:37
[2013-07-30 11:37:11] |
Hendrixon - Posts: 130 |
1. From which SC version does this work? 2. The MS timestamp comes from the feed provider or is it printed by SC at local arrival time? 3. Rithmic data has MS resolution timestamp? 4. The "historical tick data" (back fill) from Optimus comes with MS timestamps? This update is really appreciated. |
[2013-07-30 21:00:22] |
TastyRisk - Posts: 119 |
So can an accurate chart overlay be obtained with this new code ? Example picture from v951 overlaying main chart data into region#2. Date Time Of Last Edit: 2013-07-30 21:03:35
