Date/Time: Thu, 02 May 2024 07:33:27 +0000
Long Period Volume by Price Charts
View Count: 1345
[2013-07-03 06:03:37] |
Ares_Bowman - Posts: 5 |
Hi, I'd like to build some long term Volume by Price (VbP) studies. I use IQFeed as my datafeed and have the download historical intraday data set to ticks with 1825days set as the maximum download. After setting up an intraday (1440min) chart using the QCL# symbol and downloading data it seems the maximum amount of data available from the server is 2years. I'm somewhat confused by this as IQfeed states that 120days of tick data is available and 5+years of minute data. I could use some help in understanding what the 2years worth of data is that I am getting for the QCL# symbol. Also if I build a VbP study on the 1440min chart with a 2year study length and use a 1tick resolution, what am I actually getting? Thanks |
[2013-07-03 09:05:14] |
Follow through all of the steps in help topic 42.1 to get all of the available data: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Not sure what you are asking with the last question. What you are going to get is based upon the chart settings, the study settings, and the available data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-03 09:05:34
