Date/Time: Sun, 05 May 2024 07:51:40 +0000
DAX data missing
View Count: 630
[2016-03-07 17:27:04] |
phaedonk - Posts: 350 |
There seems to be a problem with the DAX data feed. From 17:13 (Eurex time) onwards. Also, a gap in data from 17:32-17:45. Don't think there was a problem with the exchange. Can you check please?
[2016-03-07 17:38:26] |
We are checking this now.
[2016-03-07 17:46:42] |
Confirming there is a problem. Barchart operations has been notified of this. Later today we will patch the missing data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-07 17:47:25] |
OK, thank you.
[2016-03-07 17:48:49] |
We have patched the missing data for the DAX March contract. Follow the instructions here to re-download the data: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
