Date/Time: Sun, 05 May 2024 00:22:24 +0000
Charts appear to have started linking but I didn't change settings
View Count: 605
[2016-03-07 05:08:44] |
skelcap - Posts: 139 |
In the attached chartbook, it appears that the ES charts have just started linking. When I move the mouse scroll across one all the others on a lower time scale scroll too. I don't know if that is what is called linking because I haven't used it before, however if I look at the Chart Linking settings nothing is set so I don't know what is causing this unwanted behaviour.
[2016-03-07 07:11:37] |
Uncheck Tools >> Synchronize Charts. Otherwise, this would be caused by the Chart Linking settings, but we do not see chart linking enabled on your charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-07 12:10:37] |
Ok thank you, sorry to bother you for such a seemingly trivial question but it was driving me crazy!
