Date/Time: Sat, 04 May 2024 09:26:08 +0000
SCDateTimeArrayRef for custom custom arrays
View Count: 615
[2016-03-06 15:29:58] |
@sstfrederik - Posts: 403 |
Disregard this port. For future reference : Creating a persistent array of SCDateTime can be done through this code example: https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations Date Time Of Last Edit: 2016-03-06 21:04:32
[2016-03-06 21:22:59] |
You would have to dynamically create this. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations If it is a smaller number of them, you could always use Persistent Variables: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetPersistentInt Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
