Date/Time: Sun, 28 Apr 2024 10:36:03 +0000
Possible feature?
View Count: 586
[2016-03-06 14:07:53] |
ScoTTyBEEE - Posts: 5 |
Hi. I'm recently moving from a long time ensign user to your platform. One feature which I use a great deal and can't seem to replicate on your platform is to use the mouse scroll wheel to change between tool configs when you have a tool selected. Is this possible at all? If not is it something you'd consider adopting? Thanks, Scott. |
[2016-03-06 20:19:17] |
This is not supported. There are Menu Commands, Control Bar buttons , and keyboard shortcuts for changing the tool configuration. There are no plans to add anything else in regards to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-06 20:19:44
[2016-03-06 20:33:40] |
No problem. Thanks for your fast response.
