Date/Time: Thu, 02 May 2024 21:14:48 +0000
Most lines in spreadsheet are showing zero instead of correct VbP Visible Bars values
View Count: 609
[2016-03-06 02:02:25] |
User534053 - Posts: 25 |
Screenshot shows the problem. For some reason most of the lines in the spreadsheet are showing zero instead of the correct VbP values.
2016-03-05_1757.png / V - Attached On 2016-03-06 02:01:28 UTC - Size: 12.82 KB - 211 views |
[2016-03-06 03:21:20] |
What is the Volume Graph Period Type Input set to with the Volume by Price study?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-06 03:21:32
[2016-03-06 03:27:18] |
It's set to "Visible Bars".
[2016-03-06 03:36:07] |
Output of the Subgraph values to the Spreadsheet when using "Visible Bars" does not work reliably because the calculations are delayed. You can see the values in Window >> Tool Values Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-06 03:36:35
[2016-03-06 03:37:52] |
I see. Thanks for your help!
