Date/Time: Tue, 07 May 2024 19:56:34 +0000
Default keyboard shortcut for bar spacing
View Count: 801
[2016-03-04 14:40:55] |
User34124 - Posts: 271 |
With regards to: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing How can I modify the up/down arrow key to change the scaling in intervals of 3 pixels, not 1? For example, this can be done using the button for Bar Spacing in the control toolbar, so I assume there is a function for the keyboard shortcut as well? |
[2016-03-04 18:26:47] |
Set up Keyboard Shortcuts for Chart >> Large Decrease Spacing and Large Increase Spacing. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts Although it is not controllable as to how many pixels the bar spacing increases by. This is fixed to 5. But we could add a setting for this if necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-04 18:27:10
[2016-03-04 21:02:16] |
Ah ok. Well I can get round it with my macro, so either way it's up to you. I was just assuming it may have already been existing.
