Date/Time: Wed, 08 May 2024 10:09:10 +0000
DVP(Draw Volume Profile) not working in custom proprietary DTC server
View Count: 936
[2016-03-04 14:40:20] |
Guilherme - Posts: 66 |
Hi. I'm pluging Sierra into my own DTC server, which I'm developing now. It used to work very well, but for some reason today the DVP tool is not working. I select it but cannot draw it on chart. Is there any reason that would cause it? I was getting this in the beginning of the implementation, when the date/time field was not correct. But since I fixed it, everything was working fine. Any hint? |
[2016-03-04 18:52:53] |
When you draw the Volume Profile, is it listed in Tools >>Manage Chart Drawings Window? Make sure Chart >> Hide Chart Drawings is disabled. There might also be an out of order timestamp in the chart. You can check that with this study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s124 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
