Date/Time: Sun, 19 May 2024 16:56:34 +0000
"all or none" type order
View Count: 620
[2016-03-04 09:51:13] |
wat - Posts: 67 |
Hello, i wonder if is possible to set in sierra chart order "all or none" ? I am talking about GC futures. U can see on my screenshot, i ve set limit take profit, price was on and above my TP several times and even one contract wasnt filled, i think volume was high enough. I understand that is possible, i am just asking may i set or cancel order type "all or none" ? Does Sierra chart provide this type of order ? Thank you for your response Date Time Of Last Edit: 2016-03-04 12:41:19
limit order 10 contratcts.png / V - Attached On 2016-03-04 09:49:29 UTC - Size: 42.06 KB - 191 views |
[2016-03-04 18:03:21] |
This is a Time in Force setting. It is not supported for Attached Orders. We see this is simulated trading you are referring to. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/doc_TradeSimulation.php#HowOrdersAreFilled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-04 18:03:36
