Date/Time: Fri, 03 May 2024 09:12:29 +0000
saved charts
View Count: 1396
[2013-07-02 12:16:42] |
rickit - Posts: 8 |
Can Sierra charts automatically open the chart that was showing when I closed the program previously?
[2013-07-02 16:41:20] |
Yes. You need to save your charts as a Chartbook. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#SaveChartbook After this, you need to set it to automatically open by following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#AutomaticallyOpenChartbook We have linked to specific sections on the Chartbooks page in the links given above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
