Date/Time: Fri, 03 May 2024 05:49:04 +0000
Data downloaded per Instrument Per day
View Count: 1347
[2013-07-02 10:19:45] |
CarlRostron - Posts: 80 |
I am going to get a netbook / laptop to take on my travels around the country with work. I will need a Dongle from a Telecoms carrier to get the SC data through. I currently use 6 instruments which are FX currency pairs on the FXCM data feed. Have you any idea on a daily basis how much data that would be downloaded (On average) so I can calculate this over a month? |
[2013-07-02 16:53:58] |
Run the Windows Task Manager. Go to the Networking tab. Select View >> Columns and add the Bytes Received column. You can then clearly measure this over a period of time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-02 16:54:19
