Date/Time: Wed, 08 May 2024 10:53:32 +0000
Count Down Timer
View Count: 555
[2016-03-03 20:01:15] |
User848740 - Posts: 12 |
AMP is my broker I frequently use 1 or two minute charts with a current price line and a Count Down timer study. The count down timer doesn't change by the second but changes only afterward ten or fifteen ticks. Why doesn't it track the seconds one by one instead of pausing and then jumping ten or fifteen seconds at a time? Fred |
[2016-03-04 05:35:23] |
There is a setting for this. It is fully documented here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s201 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
