Date/Time: Thu, 02 May 2024 10:55:20 +0000
last bar on intraday chart
View Count: 895
[2016-03-03 15:56:55] |
User170575 - Posts: 221 |
Good morning, Seems I am getting some bad data on the last bar of my intraday charts--I have del and downloaded but it happens again. Here is an example: http://www.sierrachart.com/image.php?l=1457020418524.png Ameritrade is the source. Have a nice day, Cy |
[2016-03-03 15:58:31] |
it is not always the last bar: http://www.sierrachart.com/image.php?l=1457020664599.png |
[2016-03-03 18:05:09] |
It looks correct for us: http://www.sierrachart.com/image.php?l=145702823826.png So it becomes correct after re-downloading the data that is not correct? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-03 19:54:07] |
this is before the del and update: http://www.sierrachart.com/image.php?l=1457034516941.png after the del and update: http://www.sierrachart.com/image.php?l=1457034635377.png ----this is a chart that is linked to a ticker list----in other words not building bars http://www.sierrachart.com/image.php?l=1457034684226.png |
[2016-03-03 22:20:42] |
We think we have seen a problem like this with TD Ameritrade before but we cannot duplicate the problem. Did this just start to occur today for no apparent reason? So we assume there was not a problem previously? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-04 00:42:09] |
It started today....i have not noticed it before....I downloaded the new version yesterday morning so I doubt that is it I'll let you know how it goes tomrw....i have had HUGE issues with TD in the past Have a nice evening |
[2016-03-04 03:20:57] |
We do not think it is related to the new version because we do not observe the problem. Consider using the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-04 13:48:46] |
I will try that at some point as I want to use some of the indicators that require the feed. The biggest problem I have with it is the 100 ticker limit |
[2016-03-04 13:53:14] |
On another note----can you plz tell me the best way to reload the intraday day for all tickers?
[2016-03-04 18:11:03] |
The 100 symbol limit is for real-time data only. And that can be increased up to 500. To re-download data for multiple symbols, refer to: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DeleteDownloadAllCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-04 19:40:54] |
Hi, regarding the re-download---that is the way I was doing it but I just noticed that it only effects the data if it is in an open chart---and it only goes back one day. is there a way to just flush the entire system of intraday data? the problem seems to be fixed---I think it was the result of me changing the chart time in the settings. have a great weekend Cy |
[2016-03-04 19:50:52] |
-and it only goes back one day. This is something that you control yourself by where you start the Delete and Download Data operation from. the problem seems to be fixed---I think it was the result of me changing the chart time in the settings. To delete all the Intraday data files, refer to: https://www.sierrachart.com/index.php?page=doc/doc_IntradayDataEditor.html#DeletingDataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
