Date/Time: Mon, 29 Apr 2024 05:33:53 +0000
vbp limit number of days to display
View Count: 647
[2016-03-03 13:54:08] |
User411334 - Posts: 38 |
Hello support. How can i limit a number of days for VbP study to display? Is it possible? I noticed that charts begin to lag a lot when there is too much vbp data displaying. For example i have 30 min chart with days to load set to 1000. But i want to display vbp for only 100 last days. I am using "multiple profiles based on fixed time" type Days. Start date and use different start date changes nothing. Thanks.
[2016-03-03 18:14:33] |
This is not supported. You have to reduce the number of days loaded in the chart.
