Date/Time: Sat, 04 May 2024 12:08:22 +0000
User Email Questions - Exchange Traded Spreads
View Count: 1447
[2013-07-01 20:30:54] |
Sierra Chart - Max - Posts: 5605 |
the profit for exchange traded spread is not currency value although having changed the setting in advanced 1 & 2, why? how to change? regards, Sierra Chart Support |
[2013-07-02 00:39:26] |
Please refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails77.html Currency Value for Exchange traded spreads is not supported as a profit/loss format unless you set up the Currency Value per Tick setting for the symbol. This help topic explains that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
