Date/Time: Thu, 02 May 2024 19:02:14 +0000
Fill with Market if touched
View Count: 1548
[2013-07-01 18:53:42] |
Jerry J Sears - Posts: 27 |
Hi, I am not getting fills when the price is touched when MIT is on. Any Ideas? Thanks, Jerry |
[2013-07-01 20:23:00] |
Yes, this does make sense based upon the Order Type. It is documented here: https://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#MarketIfTouched Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-01 20:47:26] |
Hi, Thanks for the post. I just fixed it, I believe. The lan connector at the back of my computer had a broken tab. I replaced the cable and it seems to work the way I see someone else's work. Thanks, Date Time Of Last Edit: 2013-07-01 21:27:04
[2013-07-01 21:27:44] |
OK this is good. Although we do not see how this would be related though. That seems like it would cause a network connectivity problem.
