Date/Time: Thu, 02 May 2024 08:24:35 +0000
Charts not updating
View Count: 670
[2016-03-01 03:21:09] |
User744694 - Posts: 2 |
When I login charts are about 15-20 minutes behind and do not update while chart is open. Please help.
[2016-03-01 03:48:34] |
We assume this is in regards to futures data or stock data? For futures data, refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 03:48:51
[2016-03-01 04:42:33] |
Futures. This is a trial for Top Step Trader. Sorry, I'm confused.
[2016-03-01 04:59:52] |
In that case you need to connect to your CTS T4 account that Top Step Trader should have provided you: http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 05:00:05
