Date/Time: Sat, 27 Apr 2024 07:29:40 +0000
S&P 400
View Count: 556
[2016-02-29 21:50:06] |
User700956 - Posts: 18 |
I would like to trade EMD S&P. I can not find it in the list of futures. Do I have to first get the okey from Interactive Brokers?
[2016-03-01 01:30:32] |
This symbol is listed. Go to File >> Find Symbol >> Futures. It is: EMD-######-GLOBEX If you do not see it, then update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
