Date/Time: Mon, 29 Apr 2024 00:25:42 +0000
how do I move the tabs from the bottom of the window to the top?
View Count: 552
[2016-02-29 17:04:57] |
dp7 - Posts: 26 |
I would like to move the bottom "tabs" to the top of the screen Can you provide me the command/instructions/menu? Thanks, |
2016-02-29_1348.png / V - Attached On 2016-02-29 17:04:29 UTC - Size: 101.57 KB - 209 views |
[2016-02-29 18:37:52] |
This can be done through Global Settings >> General Settings. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#Tabs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-29 20:20:46] |
dp7 - Posts: 26 |
Thank You!
