Date/Time: Fri, 03 May 2024 18:34:12 +0000
Cannot save study
View Count: 1082
[2016-02-29 12:11:47] |
User388336 - Posts: 5 |
Hi, I am trying to change settings at Daily OHLC study, but every time I change anything and press apply, whole study resets to default. I want to see High, Low and open, but it is set to ignore and every change resets after pressing apply button. Any help? Thanks |
[2016-02-29 13:06:56] |
Update: Study resets only when I try change Open from ingnore to line in subgraphs settings. As long as I keep Open set to ignore, I am able to change other settings.
[2016-02-29 19:15:12] |
This is because you have set the Display Total Daily Volume Only input to Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137_Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-01 16:52:38] |
Thank you
