Date/Time: Sat, 04 May 2024 21:42:40 +0000
Changing Timezone-Sessions after Importing a Chartbook
View Count: 1855
[2013-07-01 16:57:02] |
Ares_Bowman - Posts: 5 |
Hi, I trying out SC for the first time this week and would like to know how to properly manage/adjust session times for charts in a chartbook that I've imported from a friend in a different timezone. The chartbook has 20 charts and a lot of studies (IB, VWAP, etc) that all need to have the correct session times. Is there a way to adjust all of the charts and studies or do I have to manually go into each chart and make the adjustments? Thanks |
[2013-07-01 18:22:59] |
Zosimus - Posts: 345 |
You will have to go to the Chart Settings (F5) of each chart and change the Session Times. This is a bit of work but the plus side is that each chart can work with different sessions.
[2013-07-01 22:21:20] |
You will have to go into the Chart Settings for each chart and do this. However, you can set up the Session Times in the Global Symbol Settings for each symbol. After this when you go to each chart, you can just press Apply Global Symbol Settings in Chart >> Chart Settings. For more information, refer to: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-01 23:09:46
