Date/Time: Tue, 30 Apr 2024 01:50:13 +0000
Point and Figure Bar Period Type v1371 onwards - documentation
View Count: 880
[2016-02-28 14:34:53] |
User13668 - Posts: 291 |
This section of the documentation does not appear to cover the new bar type: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar In Chart Settings, what do the two numbers to be inserted represent? This is right below 'Bar Period: Point and Figure (in ticks)' and is shown as x-y, where x and y are to be inserted by the user. Is one box size in ticks? Also is it true that if using a Graph Draw Type of 'Point and Figure XO' that the colour of the bars (XO's) cannot be changed? This section of the documentation refers: https://www.sierrachart.com/index.php?page=doc/doc_GraphDrawTypesColorSettings.php |
[2016-02-29 09:58:01] |
The documentation should be updated by the end of the day today.
[2016-03-02 10:59:25] |
Excellent, I see you have done that. But what about the 2nd part to my post: Also is it true that if using a Graph Draw Type of 'Point and Figure XO' that the colour of the bars (XO's) cannot be changed? This section of the documentation refers: https://www.sierrachart.com/index.php?page=doc/doc_GraphDrawTypesColorSettings.php
Currently the colours for 'X' are green and 'O' are red. But the contrast is not that great on the grey background I use (see attached). Given the very nature of PnF is that the 'X' and 'O' denote direction, it is not necessary for them to be coloured separately. I would prefer to be able to change the colour to something like black for both. I tried some of the Graph Draw Type Colors, but they did not change the PnF plot colours, unless by chance it happens to be one of the styles I did not try. Is it possible for the colour of the 'X' and 'O' to be user selectable? Thanks |
ES-201603-CME [CB] Point & Figure 7-3 #22 2016-03-02 05_5.png / V - Attached On 2016-03-02 10:59:16 UTC - Size: 33.57 KB - 266 views |
[2016-03-03 04:01:57] |
We need more time to look at this. Do not post any further information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-04 22:14:57] |
The colors can be controlled in 1376 when this is available later today. The documentation has been updated here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#PointAndFigureBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
