Date/Time: Wed, 28 Oct 2026 16:56:28 +0000
spreadsheets confusing
View Count: 1224
| [2016-02-27 05:11:45] |
| jivetrader - Posts: 410 |
when i add a spreadsheet study to a chart, then from within that study i SELECT to open a previously saved spreadsheet, the data from that saved sheet does not appear on my sheet. this seems counterintuitive. how else am i supposed to load previous spreadsheet data into a new spreadsheet instance? also, when using Spreadsheet for Trading, i first created a simple system that did in fact show buy/sell arrows on the chart (after following all instructions: Creating a Trading System for Automated Trading). however after closing and reopening the sheet, it is not working. the sheet seems to be not updating the value in $J$8 Position Quantity (which i have set correctly) therefore not generating entry signals. as mentioned i have followed all instructions. can you explain, or do you need more info? |
| [2016-02-27 06:09:29] |
more information: after initially seeing the correct entry arrows on the chart, i proceeded to Backtest mode. it was after this that i could no longer see any arrows. i have been through all of the steps in Steps To Create a Trading System for Automated Trading several times now and still i cannot see any trades on the chart except previous non-simulated live trades i took (live in the market) this past week. i understand that Trade Sim mode must be OFF in order to backtest, and it is off. and again, my entry formulae have not changed. i have cell J26 set at 0, so that the Order Quantity will be determined from the chart Trade Window. in addition, when performing backtesting, the system is not taking any trades. very frustrating. |
| [2016-02-27 17:16:11] |
This Support Request is chargeable at 50 USD per hour. Your account has an excessive number of requests and advanced requests/questions. Also, none of these new questions have anything to do with any particular issues that need to be resolved in SC or documentation deficiencies. Please add a 50 USD credit to your Additional Services Balance: https://www.sierrachart.com/usercp.php?page=AddAccountCredit If you want the questions answered, this is chargeable. There are no exceptions here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-27 20:35:29
| [2016-02-27 17:22:18] |
Also refer to this page here: http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetTradingTestProcedure.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
