Date/Time: Mon, 06 May 2024 02:32:24 +0000
Left side scale
View Count: 1806
[2016-02-26 07:11:18] |
Zdislav - Posts: 73 |
Hello Support. I am using the left side scale in some charts and often I'd like to move or change the scale dynamically like it is possible on the right side scale (ctrl+drag). But it is not possible. Documentation doesn't say anything about this. Do you have implementation of this function in your plan? https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#UseLeftSideScale Petr |
[2016-03-01 04:00:39] |
Eventually it will be supported to interactively modify the left side scale but it is not supported now. Do not expect anything will happen with this for about a year.
[2016-03-01 06:11:16] |
OK, thanks. Petr |
