Date/Time: Fri, 03 May 2024 04:43:50 +0000
Sim and live?
View Count: 623
[2016-02-25 15:07:55] |
toews&kane - Posts: 209 |
Hi there, Is there a way to go sim and live? One chart sim another live? Two chartbooks? Cheers |
[2016-02-25 18:31:48] |
No, this is not supported. You have to install another copy of Sierra Chart to do something like this. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
