Date/Time: Mon, 06 May 2024 21:15:54 +0000
setting OCO stop/targets by R/R ratio
View Count: 679
[2016-02-25 09:15:41] |
User444441 - Posts: 2 |
Hi, Is it possible to set OCO bracket orders (stops and targets) on the basis of Risk/Reward ratio? If I set a stop of 10 ticks - then the system sets a target as 2 R/R to 20 ticks. |
[2016-02-25 09:54:28] |
You have to do this manually. This does not happen automatically.
