Date/Time: Wed, 08 May 2024 19:33:10 +0000
Startup question for Chart Data
View Count: 648
[2016-02-25 02:29:52] |
User316362 - Posts: 210 |
It appears that all data is being reloaded (downloaded?) when i bring up sierra charts each day. Is there a setting that only loads the missing data from where it left off from the previous sierra chart usage? This may be fine but for a few chart where I have hundreds of days to load this takes some time to do when I start up in the morning. Is this time being taken for "loading" the already downloaded data into the chart for each contract? Or is it downloads each time? Thanks |
[2016-02-25 04:41:23] |
Definitely the data is only being loaded from the local data file. Only the data that is missing from the chart is downloaded. This section makes that clear: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#MissingOrIncompleteIntradayChartData Also refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-25 04:43:59
