Date/Time: Mon, 20 May 2024 08:53:39 +0000
Trade Activity Log - importing symbols with fractions in price not populating
View Count: 673
[2016-02-25 01:24:00] |
User264623 - Posts: 26 |
I am using two computers (a laptop while traveling, and a desktop otherwise) to trade a single account. To populate the missing orders on each computer's trade activity log I am using the export and import function to save time over the manual insert entry. Two issues with importing Trade Activity Log: 1) When importing an instrument with price fractions (i.e. ZB, 30 year bond), the fraction part is not populated on the import. Example: Entry price is 164 12/32.... the imported entry price shows 164 0/32. Only the whole number portion is being transferred. The exported text file contains the complete price however. I manually edited each fill record in in the trade activity log to correct the missing fraction, but is there a more efficient solution? 2) My DTS time zone is set to New York (-5 EST /-4 EDT), on both computers. The exported trade activity log txt file outputs the order fills in this time zone... however the import fill records are in UTC. How do I get the time to stay consistent? Thank you |
[2016-02-25 01:32:00] |
Correction: NOT UTC time. (the opposite actually). The displayed order fill times on the imported records are -5 or -4 hours less than the original order fill (depending on season). Example: Original order fill occurred at 10:07:30... the imported fill record displays 05:07:30. In contrast to the exported txt file - which displays 10:07:30. |
[2016-02-25 03:50:05] |
1. This is fixed. The new release will be out in a couple of hours. 2. We will come up with a solution for this. Just give us one or two days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
