Date/Time: Fri, 26 Apr 2024 14:29:42 +0000
[User Discussion] - extend naked close
View Count: 970
[2013-07-01 14:10:04] |
User77503 - Posts: 48 |
is there a way i can extend the closing price until interesection, like is possible with a vpoc using the volume by price? i would like to do this on a volume profile and/or TPO chart if possible.
[2013-07-01 22:09:41] |
No, this is not supported.
[2013-07-01 22:12:31] |
ok, can i make a request for it?
[2013-07-02 00:14:27] |
Not at this time. We have too much to do. It is not even realistic for us to say we are going to do it when we're not going to get to it for a very long time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-02 00:14:55
[2014-05-19 20:12:35] |
User97684 - Posts: 136 |
Extend naked close - it's close to an year since this was last requested, would you please reconsider, since it is a key feature for VP traders and is generally a common feature. Thank you
