Date/Time: Sun, 05 May 2024 13:25:33 +0000
Data folder revisit
View Count: 674
[2016-02-24 19:48:02] |
GreyLock58 - Posts: 168 |
Is there a way to concatenate .dly files per symbol in the data folder. This would make the data folder much more manageable.
[2016-02-24 20:25:45] |
We do not understand the question.
[2016-02-24 20:46:38] |
When I download Historical data via "SC Data All Services" I get multiple .dly files per symbol. For example, downloading ES minis march contract will show up as "ESH16.dly","ESH15.dly","ESH14.dly","ESH13.dly",ESH12.dly",ESH11.dly" and so on. Is it possible to combine theses files so that there is just one per contract month?
[2016-02-24 21:08:26] |
I hit user discussion by mistake thus the renamed post.
[2016-02-24 22:48:33] |
The files definitely cannot be combined. They must remain separate.
