Date/Time: Mon, 29 Apr 2024 14:06:21 +0000
cursor only moves in 1 point increments
View Count: 667
[2016-02-24 17:30:53] |
User900519 - Posts: 13 |
On the 1 min SPX500 chart my cursor can only move in 1 point increments so it is hard to draw boxes etc with any accuracy. How can I remedy this?
[2016-02-24 17:58:42] |
Check the Chart >> Chart Settings >> Tick Size. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ToolValuesAdjustToNearestTick Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
