Date/Time: Tue, 07 May 2024 18:11:29 +0000
[Programming Help] - Unusual indicator value when autoloop set to 0
View Count: 771
[2016-02-24 03:20:20] |
User972044 - Posts: 154 |
Hello there, I have set autoloop to 0 now and this is what I have observed for an indicator value in this trading study that I created: Chart: GBPUSD [M] 1 Min #1 | Study: Custom DLL Study | StochRSI: 26815615859885194000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000 RSI: 0.000000 MACD: 0.000000 | 2016-02-23 22:02:00 I have another study file that I created and it was loaded on EXACTLY the same chart and for the same indicator value also for autoloop = 0 and set up EXACTLY the same way with the same variable and function; everything the same, and this is what is displayed: Chart: GBPUSD [M] 1 Min #1 | Study: Custom DLL Study | StockRSI value at index 88540 is 0.348975 | 2016-02-23 22:12:13 * This is NOT asking for programming help and I am not expecting you to give any. I just want to know what does this LONG number of this invalid value in the first StochRSI indicate and I will debug and analyze my codes myself and find out WHY when everything EXACTLY the same written into two different studies would give two totally different results. Thank you for your help. Date Time Of Last Edit: 2016-02-24 03:41:55
[2016-02-24 04:53:53] |
This is most definitely considered programming help and we do not know the answer to the question.
[2016-02-24 06:08:48] |
StochRSI: 26815615859885194000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000 You don't know what this error message indicate? That's all I want to know. I am not asking you to fix this. Thanks for your help. |
