Date/Time: Sat, 04 May 2024 17:00:56 +0000
Turn Off Confirmation Box
View Count: 979
[2016-02-23 22:15:50] |
User765038 - Posts: 22 |
SC Support, When I select: "Chart >> Hide Chart Drawings", a confirmation box: "Do you want to hide the Chart Drawings on the active chart?" appears. Can I switch this off? Thanks and regards, Rod |
[2016-02-23 22:29:18] |
No, you cannot.
[2016-02-24 13:06:17] |
phaedonk - Posts: 350 |
+1 to have a switch off from me. It is very annoying. I can understand the confirmation for SIM/Live, but this is unnecessary.
[2016-02-24 13:47:42] |
SC Support, I can understand the need for confirmation if the function were to delete the drawings but a confirmation box for what, I would guess, most people use as an on/off show/hide toggle, would seem to me superfluous. It is most certainly annoying. Could I recommend a revision on this one? Thanks and regards, Rod |
[2016-02-24 20:35:13] |
The reason this exists is because if someone accidentally selects it and then chart drawings do not appear and disappear after they draw them, then they are left with wondering why and think Sierra Chart is a messed up program. So this is the consequence of removing it but we will go ahead and do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-25 13:40:12] |
Thank you for that! This is now wonderful.
