Date/Time: Fri, 03 May 2024 12:03:27 +0000
Two charts same window
View Count: 1644
[2013-07-01 11:11:55] |
user54342 - Posts: 38 |
Hello support, How can I set two charts in one window? And how can I roll both toghether? Thank you Great day Julius |
[2013-07-01 20:00:12] |
Can anybody helps?
[2013-07-01 20:41:57] |
Yes. Sometimes there is a delay with responding because we want to update the documentation to explain this as best as possible, and then give you the updated documentation. What you will want to do is use the Overlay (Bar) study. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s100 Let us know if you need more help. Not sure what you mean by "roll both together"? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-01 20:42:40
[2013-07-02 05:33:28] |
Thank you
