Date/Time: Mon, 29 Apr 2024 13:25:26 +0000
Text on Top
View Count: 604
[2016-02-23 01:28:35] |
Sean Beebe - Posts: 10 |
We are using the UseTool function to draw text from a study. However other user drawn objects such as lines are placed on top of the text from the study. Is there a way to set the text so it displays on top of the lines?
[2016-02-23 17:42:33] |
There is no way currently to do this. But we will see about adding an option to draw chart drawings from Advanced Custom Studies above user drawn drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
