Date/Time: Mon, 06 May 2024 18:20:28 +0000
Visual on chart
View Count: 753
[2016-02-22 20:06:49] |
User28682 - Posts: 233 |
Hi, I have a custom study which prints a numeric reading at the top or bottom of bars on a chart. I have posted two charts. When I look at my charts in their auto pilot mode, I dont see some of these number as they are underneath the bottom of my chart bars. I have to customize the scaling to see them, then when the chart moves to new levels, I have to customize it again to see the new levels. Is there a way to change a setting to "see" all of this on my chart? ES 1 is a normal chart, ES 2 is what I need to see cause the numbers are cut off. Thanks Tom |
Attachment Deleted. |
[2016-02-24 06:03:00] |
Not if these are using the Text Drawing Tool. If the study is using a Study Subgraph to output these values as text, and it has an Independent Scale, then you will always see them on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-24 06:05:55
[2016-02-24 06:06:04] |
The prior post has been updated.
