Date/Time: Sun, 19 May 2024 06:51:57 +0000
Cant install C++ compiler
View Count: 742
[2016-02-22 16:40:33] |
buylosellhi - Posts: 60 |
Hi, I had to do a fresh install on my PC but now I'm unable to install the C++ compiler using the "Install Compiler" option. Could you please help me with this. Thanks
Compiler.PNG / V - Attached On 2016-02-22 16:40:20 UTC - Size: 27.43 KB - 222 views |
[2016-02-22 18:12:29] |
Some of those warnings and errors can be expected. Have you tried using the compiler because the installation still may be successful. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-22 18:57:09] |
I don't know how to do that. Could you please give me some pointers. I do see an exe file. My apologies if this is a trivial question. Thanks in advance
[2016-02-23 22:24:49] |
Refer to the instructions on this page: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-13 16:57:52] |
i see the compiler is installed in the SC directory but I cant seem to build any studies. And when I click on "Install Compiler" I get the error below...
Compiler installation error.PNG / V - Attached On 2016-07-13 16:57:42 UTC - Size: 74.73 KB - 234 views |
[2016-07-13 17:03:37] |
When you build an advanced custom studies source code file, copy and paste here the text from the Build Output window so we can see what the problem is. Those errors you see when installing the compiler might be normal and not cause a problem because sometimes there are errors which do not cause a problem. However, they do appear as though that they are a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-13 17:56:09
[2016-07-13 17:38:33] |
here it is. thanks... -- Starting build of Custom Studies Source files: rrPivot.cpp. -- 13:37:35
The compiler is not installed. Press the 'Install Compiler' button and complete the installation before trying to build again. -- End of Build -- 13:37:35 |
[2016-07-13 17:58:09] |
For reasons which we do not know the cause of, you are having a problem installing the compiler on your system. Looks like some kind of HTTP connection issue.
