Date/Time: Mon, 06 May 2024 11:18:40 +0000
Draw on chart rather than generate an audio alert
View Count: 1378
[2013-06-30 20:37:10] |
SKY - Posts: 45 |
Hi I would like to logically check few terms and if TRUE us returned that rather generating an alert i would like to drwa an object on the chart (e.g. an arrow) could be done ? if answer is yes then pls direct me to the appropriate documentation tnx. |
[2013-06-30 21:15:05] |
See: http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-30 21:59:10] |
SKY - Posts: 45 |
It looks my question was unclear. by saying tht i want to draw a somegraphics rather than generate an alert i assumed it is clear that it should be done w/o using APIs. in case i didn't understand the question it will assist if u can point an example tnx! |
[2013-06-30 23:05:35] |
We cannot provide further help. The only way to do this is by using ACSIL (Advanced Custom study Interface and Language).
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-30 23:06:03
[2013-07-01 00:26:21] |
GPST10 - Posts: 139 |
SKY has GREAT idea.
