Date/Time: Wed, 28 Oct 2026 16:13:20 +0000
white screen
View Count: 1375
| [2016-02-19 15:43:46] |
| User635149 - Posts: 9 |
(NQ) I get a white screen and a message "symbol unknown." What to do? Thank-you |
| [2016-02-19 17:42:58] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-19 18:25:18] |
Software version: 1361 | 2016-02-19 18:20:35 Uses New Spreadsheets | 2016-02-19 18:20:35 Usage end date: 2016-03-25 | 2016-02-19 18:20:35 Enabled for: Advanced Features. | 2016-02-19 18:20:35 Enabled for: Advanced Features 2. | 2016-02-19 18:20:35 Enabled for: Sierra Chart Historical Data Service. | 2016-02-19 18:20:35 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-02-19 18:20:35 Current selected Data/Trading service: Rithmic Trading | 2016-02-19 18:20:35 Chart Update Interval: 500 | 2016-02-19 18:20:35 Time Zone: +00:00:00 (UTC+00) | 2016-02-19 18:20:35 2016-02-19 10:20:35 Local computer time | 2016-02-19 18:20:35 2016-02-19 18:20:35 Local computer time in UTC | 2016-02-19 18:20:35 2016-02-19 18:20:35 Local computer time in SC Time Zone | 2016-02-19 18:20:35 2016-02-19 18:20:42 Server time in UTC | 2016-02-19 18:20:35 Local computer UTC time and Server UTC time difference: 7 seconds. | 2016-02-19 18:20:35 Program path: C:\SierraChart\ | 2016-02-19 18:20:35 Data Files path: C:\SierraChart\Data\ | 2016-02-19 18:20:35 OS Version Number: 6.1 | 2016-02-19 18:20:35 Locale Information: C | 2016-02-19 18:20:35 Checking for new symbol settings for rim | 2016-02-19 18:20:36 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-19 18:20:36 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-02-19 18:20:36 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-02-19 18:20:36 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-02-19 18:20:36 Symbol settings are up-to-date for rim | 2016-02-19 18:20:37 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-19 18:20:38 HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-02-19 18:20:38 Files to Open on Start up | Opening file: GC.cht | 2016-02-19 18:20:39 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Error creating Intraday data file: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Files to Open on Start up | Opening file: YM.cht | 2016-02-19 18:20:40 Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:40 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:40 Files to Open on Start up | Opening file: CL.cht | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\Base Gra.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:41 Error creating Intraday data file: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:41 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\üéL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\üéL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\üéL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\üéL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\üéL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\üéL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\üéL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\üéL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\êL.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\2016-02-.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:42 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:42 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:43 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Files to Open on Start up | Opening file: TF.cht | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:43 Files to Open on Start up | Opening file: ES.cht | 2016-02-19 18:20:43 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:44 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:44 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:44 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\P1¿ .scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Error creating Intraday data file: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:45 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Files to Open on Start up | Opening file: NQ.cht | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:45 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:46 Error creating Intraday data file: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to get dates from Intraday data file. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for reading. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:46 * 2016-02- 15 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 30 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 45 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 60 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 120 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 180 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 240 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 2016-02- 1 Day #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:46 NQH6-CME- 15 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 NQH6-CME- 30 Min #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 NQH6-CME- 45 Min #20 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 NQH6-CME- 60 Min #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 NQH6-CME- 120 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 NQH6-CME- 180 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 NQH6-CME- 240 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 15 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 30 Min #28 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 45 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 60 Min #30 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 120 Min #31 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 180 Min #32 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 240 Min #33 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 GCJ6-COMEX I 1 Day #34 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCJ6-COMEX I.scid | 2016-02-19 18:20:46 YMH6-CBOT- 15 Min #35 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:46 Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * Error opening or reading chart data file. File: C:\SierraChart\Data\YMH6-CBO.scid | 2016-02-19 18:20:46 * NQH6-CME- 15 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 30 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 45 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 60 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 120 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 180 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 240 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 NQH6-CME- 1 Day #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 TR:44m 9s 15 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 30 Min #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 45 Min #20 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 60 Min #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 120 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 180 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 240 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:44m 9s 1 Day #25 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~44m 9s.scid | 2016-02-19 18:20:47 TR:43m 53s 15 Min #26 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~43m 53s.scid | 2016-02-19 18:20:47 Base Graph 30 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Base Graph.scid | 2016-02-19 18:20:47 Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\Base Gra.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\TR~9m 23.scid | 2016-02-19 18:20:47 * YMH6-CBOT- 15 Min #44 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 YMH6-CBOT- 30 Min #45 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-02-19 18:20:47 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-02-19 18:20:47 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-02-19 18:20:47 YMH6-CBOT- 45 Min #46 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 YMH6-CBOT- 60 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 YMH6-CBOT- 120 Min #48 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 YMH6-CBOT- 180 Min #49 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 YMH6-CBOT- 240 Min #50 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 YMH6-CBOT- 1 Day #51 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMH6-CBOT-.scid | 2016-02-19 18:20:47 TR:11m 39s 15 Min #52 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~11m 39s.scid | 2016-02-19 18:20:47 Date Time Array 30 Min #53 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 45 Min #54 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 60 Min #55 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 120 Min #56 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 180 Min #57 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 240 Min #58 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 1 Day #59 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Date Time Array 15 Min #60 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Date Time Array.scid | 2016-02-19 18:20:47 Error opening or reading chart data file. File: C:\SierraChart\Data\üéL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\êL.scid | 2016-02-19 18:20:47 * 987 15 Min #70 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 30 Min #71 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 45 Min #72 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 60 Min #73 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 120 Min #74 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 180 Min #75 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 240 Min #76 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 987 1 Day #77 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\987.scid | 2016-02-19 18:20:47 Region 1 15 Min #78 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 30 Min #79 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 45 Min #80 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 60 Min #81 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 120 Min #82 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 180 Min #83 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 240 Min #84 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 Region 1 1 Day #85 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Region 1.scid | 2016-02-19 18:20:47 # of Trades 15 Min #86 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 30 Min #87 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 45 Min #88 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 60 Min #89 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 120 Min #90 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 180 Min #91 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 240 Min #92 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 1 Day #93 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 2016-02- 15 Min #94 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 30 Min #95 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 45 Min #96 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 Error opening or reading chart data file. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 * End Of Window 15 Min #102 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 30 Min #103 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 45 Min #104 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 60 Min #105 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 120 Min #106 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 180 Min #107 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 240 Min #108 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 End Of Window 1 Day #109 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CMEscid.scid | 2016-02-19 18:20:47 * 2016-02- 60 Min #118 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 120 Min #119 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 180 Min #120 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 240 Min #121 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 1 Day #122 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 Chart #124 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #124 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #123 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #123 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #125 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #125 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #127 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #127 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 TR:2h 21m 14s 15 Min #131 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 Chart #126 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #126 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 TR:2h 21m 14s 30 Min #132 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 TR:2h 21m 14s 45 Min #133 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 TR:2h 21m 14s 60 Min #134 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 TR:2h 21m 14s 120 Min #135 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 Chart #129 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #129 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #128 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #128 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 TR:2h 21m 14s 180 Min #136 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 TR:2h 21m 14s 240 Min #137 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 Chart #130 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 Chart #130 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:47 TR:2h 21m 14s 1 Day #138 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~2h 21m 14s.scid | 2016-02-19 18:20:47 HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-02-19 18:20:47 HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-02-19 18:20:47 Chart #7 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:47 Chart #7 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:47 TR:1h 22m 23s 15 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 30 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 45 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 60 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 120 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 180 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 240 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 TR:1h 22m 23s 1 Day #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 23s.scid | 2016-02-19 18:20:47 2016-02- 15 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 30 Min #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 45 Min #20 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 60 Min #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 120 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 180 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 240 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 2016-02- 1 Day #25 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2016-02-.scid | 2016-02-19 18:20:47 ESH6-CME- 15 Min #26 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:47 Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:47 ESH6-CME- 30 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 ESH6-CME- 45 Min #28 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 ESH6-CME- 60 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 ESH6-CME- 120 Min #30 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 ESH6-CME- 180 Min #31 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 ESH6-CME- 240 Min #32 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 ESH6-CME- 1 Day #33 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME-.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 15 Min #34 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 30 Min #35 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 45 Min #36 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 60 Min #37 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 120 Min #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 180 Min #39 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 240 Min #40 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 22s 1 Day #41 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 22s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 15 Min #42 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 30 Min #43 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 45 Min #44 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 60 Min #45 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 120 Min #46 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 180 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 240 Min #48 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 TR:1h 22m 20s 1 Day #49 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 20s.scid | 2016-02-19 18:20:47 Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\P1¿ .scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\GCJ6-COM I.scid | 2016-02-19 18:20:47 * TR:1h 22m 9s 15 Min #66 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 30 Min #67 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 45 Min #68 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 60 Min #69 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 120 Min #70 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 180 Min #71 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 240 Min #72 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 22m 9s 1 Day #73 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 22m 9s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 15 Min #74 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 30 Min #75 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 45 Min #76 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 60 Min #77 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 120 Min #78 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 180 Min #79 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 240 Min #80 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 TR:1h 21m 56s 1 Day #81 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TR~1h 21m 56s.scid | 2016-02-19 18:20:47 ESH6-CME I 15 Min #82 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 30 Min #83 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 45 Min #84 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 60 Min #85 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 120 Min #86 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 180 Min #87 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 240 Min #88 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 ESH6-CME I 1 Day #89 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6-CME I.scid | 2016-02-19 18:20:47 # of Trades 15 Min #90 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 30 Min #91 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 45 Min #92 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 60 Min #93 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 120 Min #94 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 180 Min #95 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 240 Min #96 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 # of Trades 1 Day #97 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\# of Trades.scid | 2016-02-19 18:20:47 NQH6-CME- 15 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6-CME-.scid | 2016-02-19 18:20:47 Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:47 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:48 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:48 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:48 * Error opening or reading chart data file. File: C:\SierraChart\Data\NQH6-CME.scid | 2016-02-19 18:20:48 * Rithmic Trading | Port for executable: 50588 | 2016-02-19 18:20:48 Listening socket (780), port 50588 | Closed. | 2016-02-19 18:20:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-19 18:20:48 CLJ6-NYMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: CL.cht | 2016-02-19 18:20:48 TF FMH0016!-NYBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: TF.cht | 2016-02-19 18:20:48 ESH6-CME 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2016-02-19 18:20:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50588 | 2016-02-19 18:20:50 Socket (5) | Connected. | 2016-02-19 18:20:50 Rithmic Trading | Connected to server. | 2016-02-19 18:20:50 Rithmic Trading | Sending Encoding Request to server | 2016-02-19 18:20:50 Rithmic Trading | Setting DTC Encoding to Binary | 2016-02-19 18:20:50 Rithmic Trading | Sending logon request message. | 2016-02-19 18:20:50 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-02-19 18:20:50 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-19 18:20:50 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-02-19 18:20:50 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-02-19 18:20:51 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-02-19 18:20:51 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-02-19 18:20:52 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-02-19 18:20:52 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-02-19 18:20:52 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-02-19 18:20:52 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-02-19 18:20:53 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-02-19 18:20:53 Rithmic Trading | Received logon response. | 2016-02-19 18:20:54 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-02-19 18:20:54 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-02-19 18:20:54 Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2016-02-19 18:20:54 Rithmic Trading | Trading is supported. | 2016-02-19 18:20:54 Rithmic Trading | Order cancel and replace is supported. | 2016-02-19 18:20:54 Rithmic Trading | Connected to data and trading server. | 2016-02-19 18:20:54 Rithmic Trading | OCO Orders supported. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: ESH6-CME. ID: 1 | 2016-02-19 18:20:54 Intraday data recording state for symbol ESH6-CME is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 2 | Downloading Intraday chart data for ESH6-CME to the file ESH6-CME.scid. Service: cme | 2016-02-19 18:20:54 HD Request # 2 | Download start Date-Time: 2016-02-19 18:20:18.000 | 2016-02-19 18:20:54 HD Request # 2 | Error downloading historical Intraday data for ESH6-CME. Not downloading Intraday data for symbol ESH6-CME. Less than 10 minutes since last record Date-Time. | 2016-02-19 18:20:54 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6-CME | 2016-02-19 18:20:54 HD Request # 2 | Intraday download COMPLETE for ESH6-CME. Completion time: 0s. Unique request ID: 1 | 2016-02-19 18:20:54 Removed historical data download ID 1 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for ESH6-CME | 2016-02-19 18:20:54 Intraday chart data file opened for ESH6-CME | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol ESH6-CME is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 3 | Downloading Intraday chart data for ESH6-CME to the file ESH6-CME.scid. Service: rim | 2016-02-19 18:20:54 HD Request # 3 | Download start Date-Time: 2016-02-19 18:20:18.000 | 2016-02-19 18:20:54 HD Request # 3 | Sending historical data request. Start Date-Time: 2016-02-19 18:20:18. Record interval: 1. Symbol: ESH6-CME | 2016-02-19 18:20:54 Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:54 Chart #5 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: 2016-02-. ID: 2 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol 2016-02- is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - 2016-02- is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: GCJ6-COM I. ID: 3 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol GCJ6-COM I is set to download 'Pending'. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: # of Trades. ID: 4 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol # of Trades is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - # of Trades is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: YMH6-CBO. ID: 5 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol YMH6-CBO is set to download 'Pending'. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: CLH6-NYMEX. ID: 6 | 2016-02-19 18:20:54 Intraday data recording state for symbol CLH6-NYMEX is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 4 | Downloading Intraday chart data for CLH6-NYMEX to the file CLH6-NYMEX.scid. Service: nymex | 2016-02-19 18:20:54 HD Request # 4 | Download start Date-Time: 2016-02-19 18:20:15.000 | 2016-02-19 18:20:54 HD Request # 4 | Error downloading historical Intraday data for CLH6-NYMEX. Not downloading Intraday data for symbol CLH6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-02-19 18:20:54 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLH6-NYMEX | 2016-02-19 18:20:54 HD Request # 4 | Intraday download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 7 | 2016-02-19 18:20:54 Removed historical data download ID 7 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for CLH6-NYMEX | 2016-02-19 18:20:54 Intraday chart data file opened for CLH6-NYMEX | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol CLH6-NYMEX is set to download 'Pending'. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: CLJ6-NYMEX. ID: 7 | 2016-02-19 18:20:54 Intraday data recording state for symbol CLJ6-NYMEX is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 5 | Downloading Intraday chart data for CLJ6-NYMEX to the file CLJ6-NYMEX.scid. Service: nymex | 2016-02-19 18:20:54 HD Request # 5 | Download start Date-Time: 2016-02-19 18:20:16.000 | 2016-02-19 18:20:54 HD Request # 5 | Error downloading historical Intraday data for CLJ6-NYMEX. Not downloading Intraday data for symbol CLJ6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-02-19 18:20:54 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLJ6-NYMEX | 2016-02-19 18:20:54 HD Request # 5 | Intraday download COMPLETE for CLJ6-NYMEX. Completion time: 0s. Unique request ID: 9 | 2016-02-19 18:20:54 Removed historical data download ID 9 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for CLJ6-NYMEX | 2016-02-19 18:20:54 Intraday chart data file opened for CLJ6-NYMEX | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol CLJ6-NYMEX is set to download 'Pending'. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: Base Graph. ID: 8 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol Base Graph is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - Base Graph is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: Base Gra. ID: 9 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol Base Gra is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - Base Gra is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: Date Time Array. ID: 10 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol Date Time Array is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - Date Time Array is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Chart #124 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Chart #123 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Chart #6 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: NQH6-CME. ID: 11 | 2016-02-19 18:20:54 Intraday data recording state for symbol NQH6-CME is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 6 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: cme | 2016-02-19 18:20:54 HD Request # 6 | Download start Date-Time: 2016-02-19 18:20:18.000 | 2016-02-19 18:20:54 HD Request # 6 | Error downloading historical Intraday data for NQH6-CME. Not downloading Intraday data for symbol NQH6-CME. Less than 10 minutes since last record Date-Time. | 2016-02-19 18:20:54 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6-CME | 2016-02-19 18:20:54 HD Request # 6 | Intraday download COMPLETE for NQH6-CME. Completion time: 0s. Unique request ID: 14 | 2016-02-19 18:20:54 Removed historical data download ID 14 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for NQH6-CME | 2016-02-19 18:20:54 Intraday chart data file opened for NQH6-CME | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol NQH6-CME is set to download 'Pending'. | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:54 Symbol Error - GCJ6-COM I is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:54 Symbol Error - YMH6-CBO is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Chart #9 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: GCJ6-COMEX. ID: 12 | 2016-02-19 18:20:54 Intraday data recording state for symbol GCJ6-COMEX is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 7 | Downloading Intraday chart data for GCJ6-COMEX to the file GCJ6-COMEX.scid. Service: comex | 2016-02-19 18:20:54 HD Request # 7 | Download start Date-Time: 2016-02-19 18:20:11.000 | 2016-02-19 18:20:54 HD Request # 7 | Error downloading historical Intraday data for GCJ6-COMEX. Not downloading Intraday data for symbol GCJ6-COMEX. Less than 10 minutes since last record Date-Time. | 2016-02-19 18:20:54 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ6-COMEX | 2016-02-19 18:20:54 HD Request # 7 | Intraday download COMPLETE for GCJ6-COMEX. Completion time: 0s. Unique request ID: 16 | 2016-02-19 18:20:54 Removed historical data download ID 16 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for GCJ6-COMEX | 2016-02-19 18:20:54 Intraday chart data file opened for GCJ6-COMEX | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol GCJ6-COMEX is set to download 'Pending'. | 2016-02-19 18:20:54 Chart #8 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:54 Chart #8 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: üéL. ID: 13 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol üéL is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - üéL is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: êL. ID: 14 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol êL is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - êL is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: 2016-02-. ID: 15 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol 2016-02- is set to download 'Pending'. | 2016-02-19 18:20:54 Chart #125 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Chart #126 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Chart #7 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: ESH6-CME-. ID: 16 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol ESH6-CME- is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - ESH6-CME- is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: NQH6-CME-. ID: 17 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol NQH6-CME- is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - NQH6-CME- is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Chart #9 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:54 Chart #9 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:54 Chart #127 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TF FMH0016!-NYBOT. ID: 18 | 2016-02-19 18:20:54 Intraday data recording state for symbol TF FMH0016!-NYBOT is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 8 | Downloading Intraday chart data for TF FMH0016!-NYBOT to the file TF FMH0016!-NYBOT.scid. Service: ice.us | 2016-02-19 18:20:54 HD Request # 8 | Download start Date-Time: 2016-02-19 18:20:17.000 | 2016-02-19 18:20:54 HD Request # 8 | Error downloading historical Intraday data for TF FMH0016!-NYBOT. Not downloading Intraday data for symbol TF FMH0016!-NYBOT. Less than 10 minutes since last record Date-Time. | 2016-02-19 18:20:54 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0016!-NYBOT | 2016-02-19 18:20:54 HD Request # 8 | Intraday download COMPLETE for TF FMH0016!-NYBOT. Completion time: 0s. Unique request ID: 23 | 2016-02-19 18:20:54 Removed historical data download ID 23 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for TF FMH0016!-NYBOT | 2016-02-19 18:20:54 Intraday chart data file opened for TF FMH0016!-NYBOT | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TF FMH0016!-NYBOT is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 3 | Receiving Intraday data for ESH6-CME starting at 2016-02-19 18:19:00 | 2016-02-19 18:20:54 Chart #8 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: NQH6-CME. ID: 19 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol NQH6-CME is set to download 'Pending'. | 2016-02-19 18:20:54 Chart #128 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Chart #129 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Chart #2 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: End Of Window. ID: 20 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol End Of Window is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 3 | Received 3 records from 2016-02-19 18:19:00 to 2016-02-19 18:20:00 (60.0 seconds) and wrote 0 records for ESH6-CME | 2016-02-19 18:20:54 HD Request # 3 | Intraday download COMPLETE for ESH6-CME. Completion time: 0s. Unique request ID: 2 | 2016-02-19 18:20:54 Removed historical data download ID 2 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for ESH6-CME | 2016-02-19 18:20:54 Intraday chart data file opened for ESH6-CME | 2016-02-19 18:20:54 Symbol Error - End Of Window is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 HD Request # 9 | Downloading Intraday chart data for 2016-02- to the file 2016-02-.scid. Service: rim | 2016-02-19 18:20:54 HD Request # 9 | Download start Date-Time: 2015-08-17 18:20:54.000 | 2016-02-19 18:20:54 HD Request # 9 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:54. Record interval: 1. Symbol: 2016-02- | 2016-02-19 18:20:54 HD Request # 9 | Error downloading historical Intraday data for 2016-02-. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:54 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 2016-02- | 2016-02-19 18:20:54 HD Request # 9 | Intraday download COMPLETE for 2016-02-. Completion time: 0s. Unique request ID: 3 | 2016-02-19 18:20:54 Removed historical data download ID 3 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for 2016-02- | 2016-02-19 18:20:54 Intraday chart data file opened for 2016-02- | 2016-02-19 18:20:54 HD Request # 10 | Downloading Intraday chart data for GCJ6-COM I to the file GCJ6-COM I.scid. Service: rim | 2016-02-19 18:20:54 Error getting file attributes for C:\SierraChart\Data\GCJ6-COM I.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 HD Request # 10 | Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:54 HD Request # 10 | Error downloading historical Intraday data for GCJ6-COM I. Not downloading any Intraday data for symbol GCJ6-COM I. | 2016-02-19 18:20:54 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ6-COM I | 2016-02-19 18:20:54 Error getting file attributes for C:\SierraChart\Data\GCJ6-COM I.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 HD Request # 10 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 * HD Request # 10 | Intraday download COMPLETE for GCJ6-COM I. Completion time: 0s. Unique request ID: 4 | 2016-02-19 18:20:54 Removed historical data download ID 4 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for GCJ6-COM I | 2016-02-19 18:20:54 Error getting file attributes for C:\SierraChart\Data\GCJ6-COM I.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 Failed to open the file C:\SierraChart\Data\GCJ6-COM I.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for GCJ6-COM I. | 2016-02-19 18:20:54 * Intraday chart data file opened for GCJ6-COM I | 2016-02-19 18:20:54 HD Request # 11 | Downloading Intraday chart data for # of Trades to the file # of Trades.scid. Service: rim | 2016-02-19 18:20:54 HD Request # 11 | Download start Date-Time: 2015-08-17 18:20:54.000 | 2016-02-19 18:20:54 HD Request # 11 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:54. Record interval: 1. Symbol: # of Trades | 2016-02-19 18:20:54 HD Request # 11 | Error downloading historical Intraday data for # of Trades. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:54 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for # of Trades | 2016-02-19 18:20:54 HD Request # 11 | Intraday download COMPLETE for # of Trades. Completion time: 0s. Unique request ID: 5 | 2016-02-19 18:20:54 Removed historical data download ID 5 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for # of Trades | 2016-02-19 18:20:54 Intraday chart data file opened for # of Trades | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:54 Symbol Error - 2016-02- is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 HD Request # 12 | Downloading Intraday chart data for YMH6-CBO to the file YMH6-CBO.scid. Service: rim | 2016-02-19 18:20:54 Error getting file attributes for C:\SierraChart\Data\YMH6-CBO.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 HD Request # 12 | Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:54 HD Request # 12 | Error downloading historical Intraday data for YMH6-CBO. Not downloading any Intraday data for symbol YMH6-CBO. | 2016-02-19 18:20:54 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH6-CBO | 2016-02-19 18:20:54 Error getting file attributes for C:\SierraChart\Data\YMH6-CBO.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 HD Request # 12 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 * HD Request # 12 | Intraday download COMPLETE for YMH6-CBO. Completion time: 0s. Unique request ID: 6 | 2016-02-19 18:20:54 Removed historical data download ID 6 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for YMH6-CBO | 2016-02-19 18:20:54 Error getting file attributes for C:\SierraChart\Data\YMH6-CBO.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:54 Failed to open the file C:\SierraChart\Data\YMH6-CBO.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for YMH6-CBO. | 2016-02-19 18:20:54 * Intraday chart data file opened for YMH6-CBO | 2016-02-19 18:20:54 HD Request # 13 | Downloading Intraday chart data for CLH6-NYMEX to the file CLH6-NYMEX.scid. Service: rim | 2016-02-19 18:20:54 HD Request # 13 | Download start Date-Time: 2016-02-19 18:20:15.000 | 2016-02-19 18:20:54 HD Request # 13 | Sending historical data request. Start Date-Time: 2016-02-19 18:20:15. Record interval: 1. Symbol: CLH6-NYMEX | 2016-02-19 18:20:54 Chart #130 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TR:2h 21m 14s. ID: 21 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TR:2h 21m 14s is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - TR:2h 21m 14s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:54 Symbol Error - NQH6-CME is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Chart #4 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Chart #3 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Chart #5 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TR:1h 22m 22s. ID: 22 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TR:1h 22m 22s is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - TR:1h 22m 22s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: YMH6-CBOT. ID: 23 | 2016-02-19 18:20:54 Intraday data recording state for symbol YMH6-CBOT is set to download 'Pending'. | 2016-02-19 18:20:54 HD Request # 14 | Downloading Intraday chart data for YMH6-CBOT to the file YMH6-CBOT.scid. Service: cbot | 2016-02-19 18:20:54 HD Request # 14 | Download start Date-Time: 2016-02-19 15:28:42.000 | 2016-02-19 18:20:54 HD Request # 14 | Using server: scdf2.sierracharts.com port 10149 | 2016-02-19 18:20:54 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TR:9m 23. ID: 24 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TR:9m 23 is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - TR:9m 23 is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Chart #6 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TR:1h 22m 9s. ID: 25 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TR:1h 22m 9s is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - TR:1h 22m 9s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TR:1h 22m 20s. ID: 26 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TR:1h 22m 20s is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - TR:1h 22m 20s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: 987. ID: 27 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol 987 is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - 987 is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: NQH6-CMEscid. ID: 28 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol NQH6-CMEscid is set to download 'Pending'. | 2016-02-19 18:20:54 Chart #7 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Chart #9 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: TR:1h 21m 56s. ID: 29 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol TR:1h 21m 56s is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - TR:1h 21m 56s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 NQH6-CME 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: NQ.cht | 2016-02-19 18:20:54 Socket (6) | Connected. | 2016-02-19 18:20:54 HD Request # 14 | Sending historical data logon request message. | 2016-02-19 18:20:54 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2016-02-19 15:28:42. Record interval: 1. Symbol: YMH16 | 2016-02-19 18:20:54 HD Request # 13 | Receiving Intraday data for CLH6-NYMEX starting at 2016-02-19 18:19:00 | 2016-02-19 18:20:54 HD Request # 13 | Received 3 records from 2016-02-19 18:19:00 to 2016-02-19 18:20:00 (60.0 seconds) and wrote 0 records for CLH6-NYMEX | 2016-02-19 18:20:54 HD Request # 13 | Intraday download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 8 | 2016-02-19 18:20:54 Removed historical data download ID 8 | 2016-02-19 18:20:54 Real-time Intraday chart data file updates started for CLH6-NYMEX | 2016-02-19 18:20:54 Intraday chart data file opened for CLH6-NYMEX | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:54 Symbol Error - NQH6-CMEscid is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied" | 2016-02-19 18:20:54 HD Request # 15 | Downloading Intraday chart data for CLJ6-NYMEX to the file CLJ6-NYMEX.scid. Service: rim | 2016-02-19 18:20:54 HD Request # 15 | Download start Date-Time: 2016-02-19 18:20:16.000 | 2016-02-19 18:20:54 HD Request # 15 | Sending historical data request. Start Date-Time: 2016-02-19 18:20:16. Record interval: 1. Symbol: CLJ6-NYMEX | 2016-02-19 18:20:54 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:54 Chart #8 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Chart #9 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:54 Rithmic Trading | Starting real-time market data updates for: P1¿ . ID: 30 | 2016-02-19 18:20:54 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:54 Intraday data recording state for symbol P1¿ is set to download 'Pending'. | 2016-02-19 18:20:54 Symbol Error - P1¿ is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:54 GCJ6-COMEX 987 Trades #26 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:54 HD Request # 14 | Decompressing data. | 2016-02-19 18:20:54 HD Request # 14 | Receiving Intraday data for YMH6-CBOT starting at 2016-02-19 15:28:42 | 2016-02-19 18:20:54 HD Request # 14 | Timestamp of first Intraday data file record written: 2016-02-19 15:28:42 | 2016-02-19 18:20:54 Chart #2 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Chart #3 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: GCJ6-COMEX I. ID: 31 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol GCJ6-COMEX I is set to download 'Pending'. | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: YMH6-CBOT-. ID: 32 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol YMH6-CBOT- is set to download 'Pending'. | 2016-02-19 18:20:55 Symbol Error - YMH6-CBOT- is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: Region 1. ID: 33 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol Region 1 is set to download 'Pending'. | 2016-02-19 18:20:55 Symbol Error - Region 1 is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: TR:1h 22m 23s. ID: 34 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol TR:1h 22m 23s is set to download 'Pending'. | 2016-02-19 18:20:55 Symbol Error - TR:1h 22m 23s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: ESH6-CME I. ID: 35 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol ESH6-CME I is set to download 'Pending'. | 2016-02-19 18:20:55 Chart #4 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Chart #5 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: TR:44m 9s. ID: 36 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol TR:44m 9s is set to download 'Pending'. | 2016-02-19 18:20:55 Symbol Error - TR:44m 9s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Chart #3 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #3 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #2 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #2 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 GCJ6-COMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:55 HD Request # 15 | Receiving Intraday data for CLJ6-NYMEX starting at 2016-02-19 18:19:00 | 2016-02-19 18:20:55 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:55 Symbol Error - GCJ6-COMEX I is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: TR:11m 39s. ID: 37 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol TR:11m 39s is set to download 'Pending'. | 2016-02-19 18:20:55 Symbol Error - TR:11m 39s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 ESH6-CME 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2016-02-19 18:20:55 Socket (6) | Shutdown and closed. | 2016-02-19 18:20:55 The network socket for historical data has been closed. | 2016-02-19 18:20:55 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:55 Symbol Error - ESH6-CME I is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 HD Request # 15 | Received 3 records from 2016-02-19 18:19:00 to 2016-02-19 18:20:00 (60.0 seconds) and wrote 0 records for CLJ6-NYMEX | 2016-02-19 18:20:55 HD Request # 15 | Intraday download COMPLETE for CLJ6-NYMEX. Completion time: 0s. Unique request ID: 10 | 2016-02-19 18:20:55 Removed historical data download ID 10 | 2016-02-19 18:20:55 Real-time Intraday chart data file updates started for CLJ6-NYMEX | 2016-02-19 18:20:55 Intraday chart data file opened for CLJ6-NYMEX | 2016-02-19 18:20:55 HD Request # 14 | Received 5594 records from 2016-02-19 15:28:42 to 2016-02-19 18:11:01 (2.7 hours) and wrote 5594 records for YMH6-CBOT | 2016-02-19 18:20:55 HD Request # 14 | Intraday download COMPLETE for YMH6-CBOT. Completion time: 0s. Unique request ID: 29 | 2016-02-19 18:20:55 Removed historical data download ID 29 | 2016-02-19 18:20:55 Real-time Intraday chart data file updates started for YMH6-CBOT | 2016-02-19 18:20:55 Intraday chart data file opened for YMH6-CBOT | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol YMH6-CBOT is set to download 'Pending'. | 2016-02-19 18:20:55 HD Request # 16 | Downloading Intraday chart data for Base Graph to the file Base Graph.scid. Service: rim | 2016-02-19 18:20:55 HD Request # 16 | Download start Date-Time: 2015-08-17 18:20:55.000 | 2016-02-19 18:20:55 HD Request # 16 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:55. Record interval: 1. Symbol: Base Graph | 2016-02-19 18:20:55 Chart #2 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 HD Request # 16 | Error downloading historical Intraday data for Base Graph. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:55 HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for Base Graph | 2016-02-19 18:20:55 HD Request # 16 | Intraday download COMPLETE for Base Graph. Completion time: 0s. Unique request ID: 11 | 2016-02-19 18:20:55 Removed historical data download ID 11 | 2016-02-19 18:20:55 Real-time Intraday chart data file updates started for Base Graph | 2016-02-19 18:20:55 Intraday chart data file opened for Base Graph | 2016-02-19 18:20:55 HD Request # 17 | Downloading Intraday chart data for Base Gra to the file Base Gra.scid. Service: rim | 2016-02-19 18:20:55 Error getting file attributes for C:\SierraChart\Data\Base Gra.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:55 HD Request # 17 | Failed to open the file C:\SierraChart\Data\Base Gra.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:55 HD Request # 17 | Error downloading historical Intraday data for Base Gra. Not downloading any Intraday data for symbol Base Gra. | 2016-02-19 18:20:55 HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for Base Gra | 2016-02-19 18:20:55 Error getting file attributes for C:\SierraChart\Data\Base Gra.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:55 HD Request # 17 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\Base Gra.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:55 * HD Request # 17 | Intraday download COMPLETE for Base Gra. Completion time: 0s. Unique request ID: 12 | 2016-02-19 18:20:55 Removed historical data download ID 12 | 2016-02-19 18:20:55 Real-time Intraday chart data file updates started for Base Gra | 2016-02-19 18:20:55 Error getting file attributes for C:\SierraChart\Data\Base Gra.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:55 Failed to open the file C:\SierraChart\Data\Base Gra.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for Base Gra. | 2016-02-19 18:20:55 * Intraday chart data file opened for Base Gra | 2016-02-19 18:20:55 HD Request # 18 | Downloading Intraday chart data for Date Time Array to the file Date Time Array.scid. Service: rim | 2016-02-19 18:20:55 HD Request # 18 | Download start Date-Time: 2015-08-17 18:20:55.000 | 2016-02-19 18:20:55 HD Request # 18 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:55. Record interval: 1. Symbol: Date Time Array | 2016-02-19 18:20:55 HD Request # 18 | Error downloading historical Intraday data for Date Time Array. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:55 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for Date Time Array | 2016-02-19 18:20:55 HD Request # 18 | Intraday download COMPLETE for Date Time Array. Completion time: 0s. Unique request ID: 13 | 2016-02-19 18:20:55 Removed historical data download ID 13 | 2016-02-19 18:20:55 Real-time Intraday chart data file updates started for Date Time Array | 2016-02-19 18:20:55 Intraday chart data file opened for Date Time Array | 2016-02-19 18:20:55 HD Request # 19 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: rim | 2016-02-19 18:20:55 HD Request # 19 | Download start Date-Time: 2016-02-19 18:20:18.000 | 2016-02-19 18:20:55 HD Request # 19 | Sending historical data request. Start Date-Time: 2016-02-19 18:20:18. Record interval: 1. Symbol: NQH6-CME | 2016-02-19 18:20:55 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:55 Chart #7 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Chart #5 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #5 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #4 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #4 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #6 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #6 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Rithmic Trading | Starting real-time market data updates for: TR:43m 53s. ID: 38 | 2016-02-19 18:20:55 Rithmic Trading | Using primary service for historical data. | 2016-02-19 18:20:55 Intraday data recording state for symbol TR:43m 53s is set to download 'Pending'. | 2016-02-19 18:20:55 Symbol Error - TR:43m 53s is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:55 Chart #4 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 Chart #3 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 Chart #5 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 CLJ6-NYMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #124 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #123 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #6 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 Chart #8 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:55 Chart #7 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #7 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:55 Chart #125 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #126 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #7 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 Chart #127 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 TF FMH0016!-NYBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: TF.cht | 2016-02-19 18:20:55 Chart #8 has tagged chart #1 for full recalculation. Chartbook: ES.cht | 2016-02-19 18:20:55 Chart #128 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #129 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #130 has tagged chart #1 for full recalculation. Chartbook: CL.cht | 2016-02-19 18:20:55 Chart #2 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:55 YMH6-CBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: YM.cht | 2016-02-19 18:20:55 Chart #4 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:55 Chart #3 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:55 Chart #5 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:55 NQH6-CME 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: NQ.cht | 2016-02-19 18:20:55 Chart #6 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:56 Chart #7 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:56 GCJ6-COMEX 987 Trades #26 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:56 Chart #8 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:56 Chart #9 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:56 GCJ6-COMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:56 HD Request # 19 | Receiving Intraday data for NQH6-CME starting at 2016-02-19 18:19:00 | 2016-02-19 18:20:56 ESH6-CME 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2016-02-19 18:20:56 Rithmic Trading | Starting real-time market data updates for: CLF6-NYMEX. ID: 39 | 2016-02-19 18:20:56 CLJ6-NYMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: CL.cht | 2016-02-19 18:20:56 YMH6-CBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: YM.cht | 2016-02-19 18:20:56 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-02-19 18:20:56 Symbol Error - CLF6-NYMEX is unknown, unavailable, or improperly formatted. | 2016-02-19 18:20:56 HD Request # 19 | Received 3 records from 2016-02-19 18:19:00 to 2016-02-19 18:20:00 (60.0 seconds) and wrote 0 records for NQH6-CME | 2016-02-19 18:20:56 HD Request # 19 | Intraday download COMPLETE for NQH6-CME. Completion time: 1s. Unique request ID: 15 | 2016-02-19 18:20:56 Removed historical data download ID 15 | 2016-02-19 18:20:56 Real-time Intraday chart data file updates started for NQH6-CME | 2016-02-19 18:20:56 Intraday chart data file opened for NQH6-CME | 2016-02-19 18:20:56 HD Request # 20 | Downloading Intraday chart data for GCJ6-COMEX to the file GCJ6-COMEX.scid. Service: rim | 2016-02-19 18:20:56 HD Request # 20 | Download start Date-Time: 2016-02-19 18:20:11.000 | 2016-02-19 18:20:56 HD Request # 20 | Sending historical data request. Start Date-Time: 2016-02-19 18:20:11. Record interval: 1. Symbol: GCJ6-COMEX | 2016-02-19 18:20:56 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:56 HD Request # 20 | Receiving Intraday data for GCJ6-COMEX starting at 2016-02-19 18:19:00 | 2016-02-19 18:20:57 HD Request # 20 | Received 3 records from 2016-02-19 18:19:00 to 2016-02-19 18:20:00 (60.0 seconds) and wrote 0 records for GCJ6-COMEX | 2016-02-19 18:20:57 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-02-19 18:21:03 | 2016-02-19 18:20:57 Added 2 Time and Sales records to Intraday data file for GCJ6-COMEX after download. | 2016-02-19 18:20:57 HD Request # 20 | Intraday download COMPLETE for GCJ6-COMEX. Completion time: 1s. Unique request ID: 17 | 2016-02-19 18:20:57 Removed historical data download ID 17 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for GCJ6-COMEX | 2016-02-19 18:20:57 Intraday chart data file opened for GCJ6-COMEX | 2016-02-19 18:20:57 HD Request # 21 | Downloading Intraday chart data for üéL to the file üéL.scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\üéL.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 21 | Failed to open the file C:\SierraChart\Data\üéL.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 21 | Error downloading historical Intraday data for üéL. Not downloading any Intraday data for symbol üéL. | 2016-02-19 18:20:57 HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for üéL | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\üéL.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 21 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\üéL.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 21 | Intraday download COMPLETE for üéL. Completion time: 0s. Unique request ID: 18 | 2016-02-19 18:20:57 Removed historical data download ID 18 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for üéL | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\üéL.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\üéL.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for üéL. | 2016-02-19 18:20:57 * Intraday chart data file opened for üéL | 2016-02-19 18:20:57 HD Request # 22 | Downloading Intraday chart data for êL to the file êL.scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\êL.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 22 | Failed to open the file C:\SierraChart\Data\êL.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 22 | Error downloading historical Intraday data for êL. Not downloading any Intraday data for symbol êL. | 2016-02-19 18:20:57 HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for êL | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\êL.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 22 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\êL.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 22 | Intraday download COMPLETE for êL. Completion time: 0s. Unique request ID: 19 | 2016-02-19 18:20:57 Removed historical data download ID 19 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for êL | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\êL.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\êL.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for êL. | 2016-02-19 18:20:57 * Intraday chart data file opened for êL | 2016-02-19 18:20:57 HD Request # 23 | Downloading Intraday chart data for 2016-02- to the file 2016-02-.scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\2016-02-.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 23 | Failed to open the file C:\SierraChart\Data\2016-02-.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 23 | Error downloading historical Intraday data for 2016-02-. Not downloading any Intraday data for symbol 2016-02-. | 2016-02-19 18:20:57 HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 2016-02- | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\2016-02-.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 23 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\2016-02-.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 23 | Intraday download COMPLETE for 2016-02-. Completion time: 0s. Unique request ID: 20 | 2016-02-19 18:20:57 Removed historical data download ID 20 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for 2016-02- | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\2016-02-.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\2016-02-.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for 2016-02-. | 2016-02-19 18:20:57 * Intraday chart data file opened for 2016-02- | 2016-02-19 18:20:57 HD Request # 24 | Downloading Intraday chart data for ESH6-CME- to the file ESH6-CME-.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 24 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 24 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: ESH6-CME- | 2016-02-19 18:20:57 HD Request # 24 | Error downloading historical Intraday data for ESH6-CME-. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6-CME- | 2016-02-19 18:20:57 HD Request # 24 | Intraday download COMPLETE for ESH6-CME-. Completion time: 0s. Unique request ID: 21 | 2016-02-19 18:20:57 Removed historical data download ID 21 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for ESH6-CME- | 2016-02-19 18:20:57 Intraday chart data file opened for ESH6-CME- | 2016-02-19 18:20:57 HD Request # 25 | Downloading Intraday chart data for NQH6-CME- to the file NQH6-CME-.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 25 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 25 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: NQH6-CME- | 2016-02-19 18:20:57 HD Request # 25 | Error downloading historical Intraday data for NQH6-CME-. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6-CME- | 2016-02-19 18:20:57 HD Request # 25 | Intraday download COMPLETE for NQH6-CME-. Completion time: 0s. Unique request ID: 22 | 2016-02-19 18:20:57 Removed historical data download ID 22 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for NQH6-CME- | 2016-02-19 18:20:57 Intraday chart data file opened for NQH6-CME- | 2016-02-19 18:20:57 HD Request # 26 | Downloading Intraday chart data for TF FMH0016!-NYBOT to the file TF FMH0016!-NYBOT.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 26 | Download start Date-Time: 2016-02-19 18:20:17.000 | 2016-02-19 18:20:57 HD Request # 26 | Sending historical data request. Start Date-Time: 2016-02-19 18:20:17. Record interval: 1. Symbol: TF FMH0016!-NYBOT | 2016-02-19 18:20:57 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:57 Chart #2 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Chart #3 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Chart #4 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Chart #5 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 HD Request # 26 | Receiving Intraday data for TF FMH0016!-NYBOT starting at 2016-02-19 18:19:00 | 2016-02-19 18:20:57 HD Request # 26 | Received 3 records from 2016-02-19 18:19:00 to 2016-02-19 18:20:00 (60.0 seconds) and wrote 0 records for TF FMH0016!-NYBOT | 2016-02-19 18:20:57 HD Request # 26 | Intraday download COMPLETE for TF FMH0016!-NYBOT. Completion time: 0s. Unique request ID: 24 | 2016-02-19 18:20:57 Removed historical data download ID 24 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TF FMH0016!-NYBOT | 2016-02-19 18:20:57 Intraday chart data file opened for TF FMH0016!-NYBOT | 2016-02-19 18:20:57 HD Request # 27 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\NQH6-CME.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 27 | Failed to open the file C:\SierraChart\Data\NQH6-CME.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 27 | Error downloading historical Intraday data for NQH6-CME. Not downloading any Intraday data for symbol NQH6-CME. | 2016-02-19 18:20:57 HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6-CME | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\NQH6-CME.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 27 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 27 | Intraday download COMPLETE for NQH6-CME. Completion time: 0s. Unique request ID: 25 | 2016-02-19 18:20:57 Removed historical data download ID 25 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for NQH6-CME | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\NQH6-CME.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\NQH6-CME.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for NQH6-CME. | 2016-02-19 18:20:57 * Intraday chart data file opened for NQH6-CME | 2016-02-19 18:20:57 HD Request # 28 | Downloading Intraday chart data for End Of Window to the file End Of Window.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 28 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 28 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: End Of Window | 2016-02-19 18:20:57 HD Request # 28 | Error downloading historical Intraday data for End Of Window. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for End Of Window | 2016-02-19 18:20:57 HD Request # 28 | Intraday download COMPLETE for End Of Window. Completion time: 0s. Unique request ID: 26 | 2016-02-19 18:20:57 Removed historical data download ID 26 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for End Of Window | 2016-02-19 18:20:57 Intraday chart data file opened for End Of Window | 2016-02-19 18:20:57 HD Request # 29 | Downloading Intraday chart data for TR:2h 21m 14s to the file TR~2h 21m 14s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 29 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 29 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:2h 21m 14s | 2016-02-19 18:20:57 HD Request # 29 | Error downloading historical Intraday data for TR:2h 21m 14s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:2h 21m 14s | 2016-02-19 18:20:57 HD Request # 29 | Intraday download COMPLETE for TR:2h 21m 14s. Completion time: 0s. Unique request ID: 27 | 2016-02-19 18:20:57 Removed historical data download ID 27 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:2h 21m 14s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:2h 21m 14s | 2016-02-19 18:20:57 HD Request # 30 | Downloading Intraday chart data for TR:1h 22m 22s to the file TR~1h 22m 22s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 30 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 30 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:1h 22m 22s | 2016-02-19 18:20:57 HD Request # 30 | Error downloading historical Intraday data for TR:1h 22m 22s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:1h 22m 22s | 2016-02-19 18:20:57 HD Request # 30 | Intraday download COMPLETE for TR:1h 22m 22s. Completion time: 0s. Unique request ID: 28 | 2016-02-19 18:20:57 Removed historical data download ID 28 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:1h 22m 22s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:1h 22m 22s | 2016-02-19 18:20:57 HD Request # 31 | Downloading Intraday chart data for TR:9m 23 to the file TR~9m 23.scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\TR~9m 23.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 31 | Failed to open the file C:\SierraChart\Data\TR~9m 23.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 31 | Error downloading historical Intraday data for TR:9m 23. Not downloading any Intraday data for symbol TR:9m 23. | 2016-02-19 18:20:57 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:9m 23 | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\TR~9m 23.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 31 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 31 | Intraday download COMPLETE for TR:9m 23. Completion time: 0s. Unique request ID: 30 | 2016-02-19 18:20:57 Removed historical data download ID 30 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:9m 23 | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\TR~9m 23.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\TR~9m 23.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for TR:9m 23. | 2016-02-19 18:20:57 * Intraday chart data file opened for TR:9m 23 | 2016-02-19 18:20:57 HD Request # 32 | Downloading Intraday chart data for TR:1h 22m 9s to the file TR~1h 22m 9s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 32 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 32 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:1h 22m 9s | 2016-02-19 18:20:57 HD Request # 32 | Error downloading historical Intraday data for TR:1h 22m 9s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:1h 22m 9s | 2016-02-19 18:20:57 HD Request # 32 | Intraday download COMPLETE for TR:1h 22m 9s. Completion time: 0s. Unique request ID: 31 | 2016-02-19 18:20:57 Removed historical data download ID 31 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:1h 22m 9s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:1h 22m 9s | 2016-02-19 18:20:57 HD Request # 33 | Downloading Intraday chart data for TR:1h 22m 20s to the file TR~1h 22m 20s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 33 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 33 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:1h 22m 20s | 2016-02-19 18:20:57 HD Request # 33 | Error downloading historical Intraday data for TR:1h 22m 20s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:1h 22m 20s | 2016-02-19 18:20:57 HD Request # 33 | Intraday download COMPLETE for TR:1h 22m 20s. Completion time: 0s. Unique request ID: 32 | 2016-02-19 18:20:57 Removed historical data download ID 32 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:1h 22m 20s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:1h 22m 20s | 2016-02-19 18:20:57 HD Request # 34 | Downloading Intraday chart data for 987 to the file 987.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 34 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 34 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: 987 | 2016-02-19 18:20:57 HD Request # 34 | Error downloading historical Intraday data for 987. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 987 | 2016-02-19 18:20:57 HD Request # 34 | Intraday download COMPLETE for 987. Completion time: 0s. Unique request ID: 33 | 2016-02-19 18:20:57 Removed historical data download ID 33 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for 987 | 2016-02-19 18:20:57 Intraday chart data file opened for 987 | 2016-02-19 18:20:57 HD Request # 35 | Downloading Intraday chart data for NQH6-CMEscid to the file NQH6-CMEscid.scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\NQH6-CMEscid.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 35 | Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 35 | Error downloading historical Intraday data for NQH6-CMEscid. Not downloading any Intraday data for symbol NQH6-CMEscid. | 2016-02-19 18:20:57 HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6-CMEscid | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\NQH6-CMEscid.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 35 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 35 | Intraday download COMPLETE for NQH6-CMEscid. Completion time: 0s. Unique request ID: 34 | 2016-02-19 18:20:57 Removed historical data download ID 34 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for NQH6-CMEscid | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\NQH6-CMEscid.scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\NQH6-CMEscid.scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for NQH6-CMEscid. | 2016-02-19 18:20:57 * Intraday chart data file opened for NQH6-CMEscid | 2016-02-19 18:20:57 HD Request # 36 | Downloading Intraday chart data for TR:1h 21m 56s to the file TR~1h 21m 56s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 36 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 36 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:1h 21m 56s | 2016-02-19 18:20:57 HD Request # 36 | Error downloading historical Intraday data for TR:1h 21m 56s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:1h 21m 56s | 2016-02-19 18:20:57 HD Request # 36 | Intraday download COMPLETE for TR:1h 21m 56s. Completion time: 0s. Unique request ID: 35 | 2016-02-19 18:20:57 Removed historical data download ID 35 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:1h 21m 56s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:1h 21m 56s | 2016-02-19 18:20:57 HD Request # 37 | Downloading Intraday chart data for P1¿ to the file P1¿ .scid. Service: rim | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\P1¿ .scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 37 | Failed to open the file C:\SierraChart\Data\P1¿ .scid. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for download. | 2016-02-19 18:20:57 HD Request # 37 | Error downloading historical Intraday data for P1¿ . Not downloading any Intraday data for symbol P1¿ . | 2016-02-19 18:20:57 HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for P1¿ | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\P1¿ .scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 HD Request # 37 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\P1¿ .scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 * HD Request # 37 | Intraday download COMPLETE for P1¿ . Completion time: 0s. Unique request ID: 36 | 2016-02-19 18:20:57 Removed historical data download ID 36 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for P1¿ | 2016-02-19 18:20:57 Error getting file attributes for C:\SierraChart\Data\P1¿ .scid. Unable to check read-only status. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2016-02-19 18:20:57 Failed to open the file C:\SierraChart\Data\P1¿ .scid for adding records. Error: Windows error code 123: The filename, directory name, or volume label syntax is incorrect. Failed to open the Intraday data file for P1¿ . | 2016-02-19 18:20:57 * Intraday chart data file opened for P1¿ | 2016-02-19 18:20:57 HD Request # 38 | Downloading Intraday chart data for GCJ6-COMEX I to the file GCJ6-COMEX I.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 38 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 38 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: GCJ6-COMEX I | 2016-02-19 18:20:57 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:57 HD Request # 38 | Error downloading historical Intraday data for GCJ6-COMEX I. Error requesting historical Minute data. Error: API_NO_DATA | 2016-02-19 18:20:57 HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ6-COMEX I | 2016-02-19 18:20:57 HD Request # 38 | Intraday download COMPLETE for GCJ6-COMEX I. Completion time: 0s. Unique request ID: 37 | 2016-02-19 18:20:57 Removed historical data download ID 37 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for GCJ6-COMEX I | 2016-02-19 18:20:57 Intraday chart data file opened for GCJ6-COMEX I | 2016-02-19 18:20:57 HD Request # 39 | Downloading Intraday chart data for YMH6-CBOT- to the file YMH6-CBOT-.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 39 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 39 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: YMH6-CBOT- | 2016-02-19 18:20:57 Chart #3 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #3 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 HD Request # 39 | Error downloading historical Intraday data for YMH6-CBOT-. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH6-CBOT- | 2016-02-19 18:20:57 HD Request # 39 | Intraday download COMPLETE for YMH6-CBOT-. Completion time: 0s. Unique request ID: 38 | 2016-02-19 18:20:57 Removed historical data download ID 38 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for YMH6-CBOT- | 2016-02-19 18:20:57 Intraday chart data file opened for YMH6-CBOT- | 2016-02-19 18:20:57 HD Request # 40 | Downloading Intraday chart data for Region 1 to the file Region 1.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 40 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 40 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: Region 1 | 2016-02-19 18:20:57 Chart #2 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #2 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 HD Request # 40 | Error downloading historical Intraday data for Region 1. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for Region 1 | 2016-02-19 18:20:57 HD Request # 40 | Intraday download COMPLETE for Region 1. Completion time: 0s. Unique request ID: 39 | 2016-02-19 18:20:57 Removed historical data download ID 39 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for Region 1 | 2016-02-19 18:20:57 Intraday chart data file opened for Region 1 | 2016-02-19 18:20:57 HD Request # 41 | Downloading Intraday chart data for TR:1h 22m 23s to the file TR~1h 22m 23s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 41 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 41 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:1h 22m 23s | 2016-02-19 18:20:57 GCJ6-COMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:57 HD Request # 41 | Error downloading historical Intraday data for TR:1h 22m 23s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 41 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:1h 22m 23s | 2016-02-19 18:20:57 HD Request # 41 | Intraday download COMPLETE for TR:1h 22m 23s. Completion time: 0s. Unique request ID: 40 | 2016-02-19 18:20:57 Removed historical data download ID 40 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:1h 22m 23s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:1h 22m 23s | 2016-02-19 18:20:57 HD Request # 42 | Downloading Intraday chart data for ESH6-CME I to the file ESH6-CME I.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 42 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 42 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: ESH6-CME I | 2016-02-19 18:20:57 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:57 HD Request # 42 | Error downloading historical Intraday data for ESH6-CME I. Error requesting historical Minute data. Error: API_NO_DATA | 2016-02-19 18:20:57 HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6-CME I | 2016-02-19 18:20:57 HD Request # 42 | Intraday download COMPLETE for ESH6-CME I. Completion time: 0s. Unique request ID: 41 | 2016-02-19 18:20:57 Removed historical data download ID 41 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for ESH6-CME I | 2016-02-19 18:20:57 Intraday chart data file opened for ESH6-CME I | 2016-02-19 18:20:57 HD Request # 43 | Downloading Intraday chart data for TR:44m 9s to the file TR~44m 9s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 43 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 43 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:44m 9s | 2016-02-19 18:20:57 HD Request # 43 | Error downloading historical Intraday data for TR:44m 9s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 43 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:44m 9s | 2016-02-19 18:20:57 HD Request # 43 | Intraday download COMPLETE for TR:44m 9s. Completion time: 0s. Unique request ID: 42 | 2016-02-19 18:20:57 Removed historical data download ID 42 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:44m 9s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:44m 9s | 2016-02-19 18:20:57 HD Request # 44 | Downloading Intraday chart data for TR:11m 39s to the file TR~11m 39s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 44 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 44 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:11m 39s | 2016-02-19 18:20:57 HD Request # 44 | Error downloading historical Intraday data for TR:11m 39s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 44 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:11m 39s | 2016-02-19 18:20:57 HD Request # 44 | Intraday download COMPLETE for TR:11m 39s. Completion time: 0s. Unique request ID: 43 | 2016-02-19 18:20:57 Removed historical data download ID 43 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:11m 39s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:11m 39s | 2016-02-19 18:20:57 HD Request # 45 | Downloading Intraday chart data for YMH6-CBOT to the file YMH6-CBOT.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 45 | Download start Date-Time: 2016-02-19 18:11:01.000 | 2016-02-19 18:20:57 HD Request # 45 | Sending historical data request. Start Date-Time: 2016-02-19 18:11:01. Record interval: 1. Symbol: YMH6-CBOT | 2016-02-19 18:20:57 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-02-19 18:20:57 Chart #7 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Chart #5 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #5 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #4 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #4 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #6 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #6 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #8 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Chart #9 has tagged chart #1 for full recalculation. Chartbook: NQ.cht | 2016-02-19 18:20:57 Chart #7 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #7 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #8 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #8 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #9 has tagged chart #1 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #9 has tagged chart #26 for full recalculation. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #2 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 Chart #4 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 Chart #3 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 Chart #5 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 Chart #6 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 Chart #7 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 NQH6-CME 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: NQ.cht | 2016-02-19 18:20:57 HD Request # 45 | Error downloading historical Intraday data for YMH6-CBOT. Error downloading historical Minute data. Error: permission denied | 2016-02-19 18:20:57 HD Request # 45 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH6-CBOT | 2016-02-19 18:20:57 HD Request # 45 | Intraday download COMPLETE for YMH6-CBOT. Completion time: 0s. Unique request ID: 44 | 2016-02-19 18:20:57 Removed historical data download ID 44 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for YMH6-CBOT | 2016-02-19 18:20:57 Intraday chart data file opened for YMH6-CBOT | 2016-02-19 18:20:57 HD Request # 46 | Downloading Intraday chart data for TR:43m 53s to the file TR~43m 53s.scid. Service: rim | 2016-02-19 18:20:57 HD Request # 46 | Download start Date-Time: 2015-08-17 18:20:57.000 | 2016-02-19 18:20:57 HD Request # 46 | Sending historical data request. Start Date-Time: 2015-08-17 18:20:57. Record interval: 1. Symbol: TR:43m 53s | 2016-02-19 18:20:57 HD Request # 46 | Error downloading historical Intraday data for TR:43m 53s. Historical data request rejected because the symbol is not valid | 2016-02-19 18:20:57 HD Request # 46 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TR:43m 53s | 2016-02-19 18:20:57 HD Request # 46 | Intraday download COMPLETE for TR:43m 53s. Completion time: 0s. Unique request ID: 45 | 2016-02-19 18:20:57 Removed historical data download ID 45 | 2016-02-19 18:20:57 Real-time Intraday chart data file updates started for TR:43m 53s | 2016-02-19 18:20:57 Intraday chart data file opened for TR:43m 53s | 2016-02-19 18:20:57 Chart #6 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:57 Chart #7 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:57 Chart #8 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 Chart #9 has tagged chart #1 for full recalculation. Chartbook: TF.cht | 2016-02-19 18:20:57 GCJ6-COMEX 987 Trades #26 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:57 Chart #8 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:57 Chart #9 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:57 GCJ6-COMEX 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: GC.cht | 2016-02-19 18:20:57 TF FMH0016!-NYBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: TF.cht | 2016-02-19 18:20:58 Chart #2 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:58 YMH6-CBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: YM.cht | 2016-02-19 18:20:58 Chart #4 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:58 Chart #3 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:58 Chart #5 has tagged chart #1 for full recalculation. Chartbook: YM.cht | 2016-02-19 18:20:58 YMH6-CBOT 987 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: YM.cht | 2016-02-19 18:20:58 |
| [2016-02-19 19:51:17] |
Almost every single symbol we see being used in this log is invalid and has the appearance in some cases of a corruption. Make sure there are no Chartbooks being automatically opened through Global Settings >> General Settings >> Files to Open on Startup. Restart Sierra Chart and do not use any of your existing Chartbooks. It appears as though they may be corrupted. You will need to start opening new charts through File >> Find Symbol. Do not manually type the symbols. Use the listed symbols only. For the record, we have never seen anything like this before and we suspect some kind of serious corruption going on within the Chartbook or the process for unknown reasons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-19 19:51:44
| [2016-02-20 00:42:04] |
When we see something like this: End Of Window 15 Min #102 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\End Of Window.scid | 2016-02-19 18:20:47 Where the symbol of the chart is a text string from a study input, this is so unbelievable that our only conclusion is that there is a malicious program interacting with Sierra Chart. You may want to check your system for viruses or other malicious programs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-22 16:59:30] |
| User635149 - Posts: 9 |
In regards to your comment "there is a malicious program interacting with Sierra Chart." I have had my system checked for viruses per your advise and nothing is found to be wrong. What do you advise now to get Sierra Charts running properly. Thank-you |
| [2016-02-22 18:09:16] |
We already gave you instructions on what to do. Refer to our response here: white screen | Post: 82139 Do not use any of your existing Chartbooks. From what we see there is something seriously wrong with all of them. If you are still having a problem, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
