Date/Time: Sun, 05 May 2024 07:53:38 +0000
Error opening the InternalOrderID.data file for writing. Windows error code 5: Access denied |
View Count: 1425
[2013-06-29 08:46:29] |
pkhst958 - Posts: 53 |
When I do backtesting I get the following message Error opening the InternalOrderID.data file for writing. Windows error code 5: Access denied | 2013-06-29 04:32:43 Problem occurs after reinstalling windows |
[2013-06-29 22:47:32] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails16.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
