Date/Time: Sat, 04 May 2024 06:35:08 +0000
profile
View Count: 1765
[2013-06-27 16:47:28] |
User28682 - Posts: 233 |
Hi all I got this volume profile working using the volume by price study. Is there a way to shorten a day of profile? I have the interactive scale range to its narrowest point. I also tried changing the maximum bar width percentage to a smaller number, but that makes the volume bars shorter, but not the days width. I want everything narrower so I can see more days. Thanks again! Tom |
ES_volume_profile_3.png / V - Attached On 2013-06-27 16:46:59 UTC - Size: 48.59 KB - 500 views |
[2013-06-30 19:31:22] |
You need to increase the timeframe per bar. In your chart it is 1 minute. You can make it 5 minutes per bar.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-30 19:31:39
[2013-06-30 23:28:37] |
Thanks, when I increase the "time period type for fixed by time" from 1 to 5 I dont even get a profile for 6/28, instead its for 6/24??? no profiles for 25,26,27,28 as you can see. And my screen is as small as I can get it. Tom |
vol_profile_4.png / V - Attached On 2013-06-30 23:28:10 UTC - Size: 56.26 KB - 471 views |
[2013-06-30 23:32:21] |
You have provided an image of a 1 minute per bar chart with a 5 day volume profile. There are also no price bars in this chart. Update: We now realize that you misunderstood. You need to change the timeframe of the bars in the chart to 5 minutes. Here is the documentation: https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChangingTheChartBarsPeriod Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-30 23:34:49
[2013-06-30 23:48:36] |
Thanks, I didnt see that before. How can I get price bars on the chart? Thanks Tom |
[2013-07-01 00:29:39] |
Select Chart >> Graph Draw Types
[2013-07-01 01:27:29] |
Thanks for your time and help! Now, lastly, can you make most of my trades winners? Tom |
[2013-07-01 01:34:01] |
Our only advice, is to be dedicated to the job of trading and keep with it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-01 01:34:25
