Date/Time: Wed, 28 Oct 2026 14:34:16 +0000
Symbols Do not update
View Count: 1300
[2016-01-31 23:35:09]
Viacheslav Malafeev - Posts: 88
No symbols are updating :( Going to Chart settings -Edit Global settings - Update from server didn't help.
Here is my log.
Software version: 1362 | 2016-01-31 17:23:52
Uses New Spreadsheets | 2016-01-31 17:23:52
Usage end date: 2016-02-17 | 2016-01-31 17:23:52
Enabled for: Advanced Features. | 2016-01-31 17:23:52
Enabled for: Sierra Chart Historical Data Service. | 2016-01-31 17:23:52
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-01-31 17:23:52
Current selected Data/Trading service: Rithmic Trading | 2016-01-31 17:23:52
Chart Update Interval: 300 | 2016-01-31 17:23:52
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-01-31 17:23:52
2016-01-31 18:23:52 Local computer time | 2016-01-31 17:23:52
2016-01-31 23:23:52 Local computer time in UTC | 2016-01-31 17:23:52
2016-01-31 17:23:52 Local computer time in SC Time Zone | 2016-01-31 17:23:52
2016-01-31 23:23:41 Server time in UTC | 2016-01-31 17:23:52
Local computer UTC time and Server UTC time difference: 6 seconds. | 2016-01-31 17:23:52
Program path: C:\SierraChart\ | 2016-01-31 17:23:52
Data Files path: C:\SierraChart\Data\ | 2016-01-31 17:23:52
OS Version Number: 6.2 | 2016-01-31 17:23:52
Locale Information: C | 2016-01-31 17:23:52
Checking for new symbol settings for rim | 2016-01-31 17:23:52
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-31 17:23:52
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-01-31 17:23:52
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-01-31 17:23:52
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-01-31 17:23:52
Requesting symbol settings for rim. Overwrite = off. | 2016-01-31 17:23:52
Symbol settings received. | 2016-01-31 17:23:53
Processed received symbol settings | 2016-01-31 17:23:53
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-31 17:23:54
HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-01-31 17:23:54
Rithmic Trading | Port for executable: 65361 | 2016-01-31 17:23:57
Listening socket (960), port 65361 | Closed. | 2016-01-31 17:23:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-01-31 17:23:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-01-31 17:23:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-01-31 17:23:57
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-01-31 17:23:57
HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-01-31 17:23:59
HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-01-31 17:23:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 65361 | 2016-01-31 17:23:59
Socket (5) | Connected. | 2016-01-31 17:23:59
Rithmic Trading | Connected to server. | 2016-01-31 17:23:59
Rithmic Trading | Sending Encoding Request to server | 2016-01-31 17:23:59
Rithmic Trading | Setting DTC Encoding to Binary | 2016-01-31 17:23:59
Rithmic Trading | Sending logon request message. | 2016-01-31 17:23:59
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-01-31 17:23:59
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-01-31 17:23:59
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2016-01-31 17:23:59
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-01-31 17:24:00
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-01-31 17:24:00
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-01-31 17:24:00
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-01-31 17:24:00
Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-01-31 17:24:00
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-01-31 17:24:00
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-01-31 17:24:00
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Broken | 2016-01-31 17:24:00
Notice: The study 'Renko Pb on Time Chart' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-31 17:24:01
Notice: The study 'Adaptive ERI Moving Average With Filters' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-31 17:24:01
Notice: The study 'Trend PB' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-31 17:24:01
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:24:01
Notice: The study 'Renko Pb on Time Chart' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-31 17:24:02
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:24:02
Notice: The study 'Trend PB' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-31 17:24:02
Chart #10 has tagged chart #9 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:04
Chart #7 has tagged chart #8 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:04
Chart #14 has tagged chart #13 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:05
Chart #12 has tagged chart #11 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:05
Chart #16 has tagged chart #15 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:05
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:05
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-01-31 17:24:07
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-01-31 17:24:07
Rithmic Trading | Received logon response. | 2016-01-31 17:24:07
Rithmic Trading | Server Name: SC DTC Bridge. | 2016-01-31 17:24:07
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-01-31 17:24:07
Rithmic Trading | Successfully connected. IB='TopstepTrader'. | 2016-01-31 17:24:07
Rithmic Trading | Trading is supported. | 2016-01-31 17:24:07
Rithmic Trading | Order cancel and replace is supported. | 2016-01-31 17:24:07
Rithmic Trading | Connected to data and trading server. | 2016-01-31 17:24:07
Rithmic Trading | OCO Orders supported. | 2016-01-31 17:24:07
SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 1 | 2016-01-31 17:24:07
SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 443 | 2016-01-31 17:24:07
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-01-31 17:24:07
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-31 17:24:07
HD Request # 2 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-01-31 17:24:08
HD Request # 2 | Download start Date-Time: 2016-01-31 17:21:39.000 | 2016-01-31 17:24:08
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-01-31 17:24:08
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-01-31 17:24:08
Socket (7) | Connected. | 2016-01-31 17:24:08
HD Request # 2 | Sending historical data logon request message. | 2016-01-31 17:24:08
Socket (6) | Connected. | 2016-01-31 17:24:08
SC DTC Data | Connected to server. | 2016-01-31 17:24:08
SC DTC Data | Sending Encoding Request to server | 2016-01-31 17:24:08
Rithmic Trading | Starting real-time market data updates for: 6EH6-CME. ID: 2 | 2016-01-31 17:24:08
Intraday data recording state for symbol 6EH6-CME is set to download 'Pending'. | 2016-01-31 17:24:08
SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-01-31 17:24:08
SC DTC Data | Sending logon request message. | 2016-01-31 17:24:08
Using Bid/Ask average for last trade price for EURUSD | 2016-01-31 17:24:08
SC DTC Data | Starting real-time market data updates for: EURUSD. ID: 3 | 2016-01-31 17:24:08
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2016-01-31 17:24:08
EURUSD [M] 150 PriceChanges #5 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:08
Rithmic Trading | Starting real-time market data updates for: CLH6-NYMEX. ID: 4 | 2016-01-31 17:24:08
Intraday data recording state for symbol CLH6-NYMEX is set to download 'Pending'. | 2016-01-31 17:24:08
CLH6-NYMEX 10 PriceChanges #8 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:08
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:21:39. Record interval: 0. Symbol: AUDJPY | 2016-01-31 17:24:08
HD Request # 2 | Decompressing data. | 2016-01-31 17:24:09
HD Request # 2 | Receiving Intraday data for AUDJPY starting at 2016-01-31 17:21:39 | 2016-01-31 17:24:09
HD Request # 2 | Timestamp of first Intraday data file record written: 2016-01-31 17:21:44 | 2016-01-31 17:24:09
Socket (7) | Shutdown and closed. | 2016-01-31 17:24:09
The network socket for historical data has been closed. | 2016-01-31 17:24:09
HD Request # 2 | Received 252 records from 2016-01-31 17:21:39 to 2016-01-31 17:24:01 (2.4 minutes) and wrote 247 records for AUDJPY | 2016-01-31 17:24:09
HD Request # 2 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 1 | 2016-01-31 17:24:09
Removed historical data download ID 1 | 2016-01-31 17:24:09
Real-time Intraday chart data file updates started for AUDJPY | 2016-01-31 17:24:09
Intraday chart data file opened for AUDJPY | 2016-01-31 17:24:09
SC DTC Data | Received logon response. | 2016-01-31 17:24:09
SC DTC Data | Server Name: SC Real-Time Server. | 2016-01-31 17:24:09
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-01-31 17:24:09
SC DTC Data | Successfully connected. | 2016-01-31 17:24:09
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-01-31 17:24:09
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-01-31 17:24:09
SC DTC Data | Restarting real-time data updates for symbol: EURUSD | 2016-01-31 17:24:09
HD Request # 3 | Downloading Intraday chart data for 6EH6-CME to the file 6EH6-CME.scid. Service: cme | 2016-01-31 17:24:09
HD Request # 3 | Download start Date-Time: 2016-01-31 17:23:17.000 | 2016-01-31 17:24:09
HD Request # 3 | Error downloading historical Intraday data for 6EH6-CME. Not downloading Intraday data for symbol 6EH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:24:09
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH6-CME | 2016-01-31 17:24:09
HD Request # 3 | Intraday download COMPLETE for 6EH6-CME. Completion time: 0s. Unique request ID: 2 | 2016-01-31 17:24:09
Removed historical data download ID 2 | 2016-01-31 17:24:09
Real-time Intraday chart data file updates started for 6EH6-CME | 2016-01-31 17:24:09
Intraday chart data file opened for 6EH6-CME | 2016-01-31 17:24:09
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:24:09
Intraday data recording state for symbol 6EH6-CME is set to download 'Pending'. | 2016-01-31 17:24:09
HD Request # 4 | Downloading Intraday chart data for 6EH6-CME to the file 6EH6-CME.scid. Service: rim | 2016-01-31 17:24:09
HD Request # 4 | Download start Date-Time: 2016-01-31 17:23:17.000 | 2016-01-31 17:24:09
HD Request # 4 | Sending historical data request. Start Date-Time: 2016-01-31 17:23:17. Record interval: 0. Symbol: 6EH6-CME | 2016-01-31 17:24:09
HD Request # 5 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2016-01-31 17:24:09
HD Request # 5 | Download start Date-Time: 2016-01-31 17:23:23.000 | 2016-01-31 17:24:09
HD Request # 5 | Using server: ds5.sierracharts.com port 10149 | 2016-01-31 17:24:09
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-01-31 17:24:09
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:24:09
Rithmic Trading | Starting real-time market data updates for: 6JH6-CME. ID: 5 | 2016-01-31 17:24:09
Socket (8) | Connected. | 2016-01-31 17:24:09
HD Request # 5 | Sending historical data logon request message. | 2016-01-31 17:24:09
Intraday data recording state for symbol 6JH6-CME is set to download 'Pending'. | 2016-01-31 17:24:09
6JH6-CME 16 PriceChanges #9 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:09
HD Request # 4 | Receiving Intraday data for 6EH6-CME starting at 2016-01-31 17:23:17 | 2016-01-31 17:24:09
HD Request # 4 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:25 | 2016-01-31 17:24:09
HD Request # 4 | Received 64 records from 2016-01-31 17:23:17 to 2016-01-31 17:24:03 (46.0 seconds) and wrote 58 records for 6EH6-CME | 2016-01-31 17:24:09
HD Request # 4 | Intraday download COMPLETE for 6EH6-CME. Completion time: 0s. Unique request ID: 6 | 2016-01-31 17:24:09
Removed historical data download ID 6 | 2016-01-31 17:24:09
Rithmic Trading | Starting real-time market data updates for: NQH6-CME. ID: 6 | 2016-01-31 17:24:09
Intraday data recording state for symbol NQH6-CME is set to download 'Pending'. | 2016-01-31 17:24:10
NQH6-CME 10 PriceChanges #11 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:10
Rithmic Trading | Starting real-time market data updates for: 6BH6-CME. ID: 7 | 2016-01-31 17:24:10
Intraday data recording state for symbol 6BH6-CME is set to download 'Pending'. | 2016-01-31 17:24:10
6BH6-CME 5 PriceChanges #13 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:10
Rithmic Trading | Starting real-time market data updates for: NGH6-NYMEX. ID: 8 | 2016-01-31 17:24:10
Intraday data recording state for symbol NGH6-NYMEX is set to download 'Pending'. | 2016-01-31 17:24:10
NGH6-NYMEX 10 PriceChanges #15 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:10
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:23:23. Record interval: 0. Symbol: EURUSD | 2016-01-31 17:24:10
HD Request # 5 | Decompressing data. | 2016-01-31 17:24:10
HD Request # 5 | Receiving Intraday data for EURUSD starting at 2016-01-31 17:23:23 | 2016-01-31 17:24:10
HD Request # 5 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:24 | 2016-01-31 17:24:10
Socket (8) | Shutdown and closed. | 2016-01-31 17:24:10
The network socket for historical data has been closed. | 2016-01-31 17:24:10
HD Request # 5 | Received 116 records from 2016-01-31 17:23:23 to 2016-01-31 17:24:03 (40.0 seconds) and wrote 115 records for EURUSD | 2016-01-31 17:24:10
Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2016-01-31 17:24:10
HD Request # 5 | Intraday download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 3 | 2016-01-31 17:24:10
Removed historical data download ID 3 | 2016-01-31 17:24:10
Real-time Intraday chart data file updates started for EURUSD | 2016-01-31 17:24:10
Intraday chart data file opened for EURUSD | 2016-01-31 17:24:10
HD Request # 6 | Downloading Intraday chart data for CLH6-NYMEX to the file CLH6-NYMEX.scid. Service: nymex | 2016-01-31 17:24:10
HD Request # 6 | Download start Date-Time: 2016-01-31 17:23:24.000 | 2016-01-31 17:24:10
HD Request # 6 | Error downloading historical Intraday data for CLH6-NYMEX. Not downloading Intraday data for symbol CLH6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:24:10
HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLH6-NYMEX | 2016-01-31 17:24:10
HD Request # 6 | Intraday download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 4 | 2016-01-31 17:24:10
Removed historical data download ID 4 | 2016-01-31 17:24:10
Real-time Intraday chart data file updates started for CLH6-NYMEX | 2016-01-31 17:24:10
Intraday chart data file opened for CLH6-NYMEX | 2016-01-31 17:24:10
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:24:10
Intraday data recording state for symbol CLH6-NYMEX is set to download 'Pending'. | 2016-01-31 17:24:10
HD Request # 7 | Downloading Intraday chart data for CLH6-NYMEX to the file CLH6-NYMEX.scid. Service: rim | 2016-01-31 17:24:10
HD Request # 7 | Download start Date-Time: 2016-01-31 17:23:24.000 | 2016-01-31 17:24:10
HD Request # 7 | Sending historical data request. Start Date-Time: 2016-01-31 17:23:24. Record interval: 0. Symbol: CLH6-NYMEX | 2016-01-31 17:24:10
HD Request # 8 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-01-31 17:24:10
HD Request # 8 | Download start Date-Time: 2016-01-31 17:24:01.000 | 2016-01-31 17:24:10
HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2016-01-31 17:24:10
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:24:10
HD Request # 7 | Receiving Intraday data for CLH6-NYMEX starting at 2016-01-31 17:23:24 | 2016-01-31 17:24:10
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-31 17:24:10
HD Request # 7 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:24 | 2016-01-31 17:24:10
HD Request # 7 | Received 17 records from 2016-01-31 17:23:24 to 2016-01-31 17:23:59 (35.0 seconds) and wrote 15 records for CLH6-NYMEX | 2016-01-31 17:24:10
Socket (9) | Connected. | 2016-01-31 17:24:10
HD Request # 8 | Sending historical data logon request message. | 2016-01-31 17:24:10
HD Request # 7 | Intraday download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 11 | 2016-01-31 17:24:10
Removed historical data download ID 11 | 2016-01-31 17:24:10
Using Bid/Ask average for last trade price for GBPUSD | 2016-01-31 17:24:10
SC DTC Data | Starting real-time market data updates for: GBPUSD. ID: 9 | 2016-01-31 17:24:10
Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2016-01-31 17:24:10
Using Bid/Ask average for last trade price for USDCAD | 2016-01-31 17:24:11
SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 10 | 2016-01-31 17:24:11
Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2016-01-31 17:24:11
Chart #3 has tagged chart #4 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:11
6EH6-CME 16 PriceChanges #4 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:11
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:11
Chart #7 has tagged chart #8 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:11
CLH6-NYMEX 10 PriceChanges #8 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:11
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:01. Record interval: 0. Symbol: AUDJPY | 2016-01-31 17:24:11
EURUSD [M] 150 PriceChanges #5 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:11
HD Request # 8 | Decompressing data. | 2016-01-31 17:24:12
HD Request # 8 | Receiving Intraday data for AUDJPY starting at 2016-01-31 17:24:01 | 2016-01-31 17:24:12
HD Request # 8 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:02 | 2016-01-31 17:24:12
Socket (9) | Shutdown and closed. | 2016-01-31 17:24:12
The network socket for historical data has been closed. | 2016-01-31 17:24:12
HD Request # 8 | Received 3 records from 2016-01-31 17:24:01 to 2016-01-31 17:24:02 (1.0 seconds) and wrote 1 record for AUDJPY | 2016-01-31 17:24:12
HD Request # 8 | Intraday download COMPLETE for AUDJPY. Completion time: 2s. Unique request ID: 5 | 2016-01-31 17:24:12
Removed historical data download ID 5 | 2016-01-31 17:24:12
Real-time Intraday chart data file updates started for AUDJPY | 2016-01-31 17:24:12
Intraday chart data file opened for AUDJPY | 2016-01-31 17:24:12
HD Request # 9 | Downloading Intraday chart data for 6JH6-CME to the file 6JH6-CME.scid. Service: cme | 2016-01-31 17:24:12
HD Request # 9 | Download start Date-Time: 2016-01-31 17:23:16.000 | 2016-01-31 17:24:12
HD Request # 9 | Error downloading historical Intraday data for 6JH6-CME. Not downloading Intraday data for symbol 6JH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:24:12
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6JH6-CME | 2016-01-31 17:24:12
HD Request # 9 | Intraday download COMPLETE for 6JH6-CME. Completion time: 0s. Unique request ID: 7 | 2016-01-31 17:24:12
Removed historical data download ID 7 | 2016-01-31 17:24:12
Real-time Intraday chart data file updates started for 6JH6-CME | 2016-01-31 17:24:12
Intraday chart data file opened for 6JH6-CME | 2016-01-31 17:24:12
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:24:12
Intraday data recording state for symbol 6JH6-CME is set to download 'Pending'. | 2016-01-31 17:24:12
Chart #21 has tagged chart #20 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:12
HD Request # 10 | Downloading Intraday chart data for 6JH6-CME to the file 6JH6-CME.scid. Service: rim | 2016-01-31 17:24:12
HD Request # 10 | Download start Date-Time: 2016-01-31 17:23:16.000 | 2016-01-31 17:24:12
HD Request # 10 | Sending historical data request. Start Date-Time: 2016-01-31 17:23:16. Record interval: 0. Symbol: 6JH6-CME | 2016-01-31 17:24:12
HD Request # 11 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: cme | 2016-01-31 17:24:12
HD Request # 11 | Download start Date-Time: 2016-01-31 17:23:21.000 | 2016-01-31 17:24:12
HD Request # 11 | Error downloading historical Intraday data for NQH6-CME. Not downloading Intraday data for symbol NQH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:24:12
HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6-CME | 2016-01-31 17:24:12
HD Request # 11 | Intraday download COMPLETE for NQH6-CME. Completion time: 0s. Unique request ID: 8 | 2016-01-31 17:24:12
Removed historical data download ID 8 | 2016-01-31 17:24:12
Real-time Intraday chart data file updates started for NQH6-CME | 2016-01-31 17:24:12
Intraday chart data file opened for NQH6-CME | 2016-01-31 17:24:12
Intraday data recording state for symbol NQH6-CME is set to download 'Pending'. | 2016-01-31 17:24:12
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:24:12
HD Request # 10 | Receiving Intraday data for 6JH6-CME starting at 2016-01-31 17:23:16 | 2016-01-31 17:24:12
HD Request # 10 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:25 | 2016-01-31 17:24:12
HD Request # 10 | Received 49 records from 2016-01-31 17:23:16 to 2016-01-31 17:23:58 (42.0 seconds) and wrote 29 records for 6JH6-CME | 2016-01-31 17:24:12
HD Request # 10 | Intraday download COMPLETE for 6JH6-CME. Completion time: 0s. Unique request ID: 14 | 2016-01-31 17:24:12
Removed historical data download ID 14 | 2016-01-31 17:24:12
HD Request # 12 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: rim | 2016-01-31 17:24:12
HD Request # 12 | Download start Date-Time: 2016-01-31 17:23:21.000 | 2016-01-31 17:24:12
HD Request # 12 | Sending historical data request. Start Date-Time: 2016-01-31 17:23:21. Record interval: 0. Symbol: NQH6-CME | 2016-01-31 17:24:12
HD Request # 13 | Downloading Intraday chart data for 6BH6-CME to the file 6BH6-CME.scid. Service: cme | 2016-01-31 17:24:12
HD Request # 13 | Download start Date-Time: 2016-01-31 17:20:36.000 | 2016-01-31 17:24:12
HD Request # 13 | Error downloading historical Intraday data for 6BH6-CME. Not downloading Intraday data for symbol 6BH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:24:12
HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BH6-CME | 2016-01-31 17:24:12
HD Request # 13 | Intraday download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 9 | 2016-01-31 17:24:12
Removed historical data download ID 9 | 2016-01-31 17:24:12
Real-time Intraday chart data file updates started for 6BH6-CME | 2016-01-31 17:24:12
Intraday chart data file opened for 6BH6-CME | 2016-01-31 17:24:12
Intraday data recording state for symbol 6BH6-CME is set to download 'Pending'. | 2016-01-31 17:24:12
HD Request # 12 | Receiving Intraday data for NQH6-CME starting at 2016-01-31 17:23:21 | 2016-01-31 17:24:12
HD Request # 12 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:36 | 2016-01-31 17:24:12
HD Request # 12 | Received 8 records from 2016-01-31 17:23:21 to 2016-01-31 17:23:51 (30.0 seconds) and wrote 4 records for NQH6-CME | 2016-01-31 17:24:12
HD Request # 12 | Intraday download COMPLETE for NQH6-CME. Completion time: 0s. Unique request ID: 15 | 2016-01-31 17:24:13
Removed historical data download ID 15 | 2016-01-31 17:24:13
Real-time Intraday chart data file updates started for NQH6-CME | 2016-01-31 17:24:13
Intraday chart data file opened for NQH6-CME | 2016-01-31 17:24:13
HD Request # 14 | Downloading Intraday chart data for 6BH6-CME to the file 6BH6-CME.scid. Service: rim | 2016-01-31 17:24:13
HD Request # 14 | Download start Date-Time: 2016-01-31 17:20:36.000 | 2016-01-31 17:24:13
HD Request # 14 | Sending historical data request. Start Date-Time: 2016-01-31 17:20:36. Record interval: 0. Symbol: 6BH6-CME | 2016-01-31 17:24:13
HD Request # 15 | Downloading Intraday chart data for NGH6-NYMEX to the file NGH6-NYMEX.scid. Service: nymex | 2016-01-31 17:24:13
HD Request # 15 | Download start Date-Time: 2016-01-31 17:23:03.000 | 2016-01-31 17:24:13
HD Request # 15 | Error downloading historical Intraday data for NGH6-NYMEX. Not downloading Intraday data for symbol NGH6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:24:13
HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NGH6-NYMEX | 2016-01-31 17:24:13
HD Request # 15 | Intraday download COMPLETE for NGH6-NYMEX. Completion time: 0s. Unique request ID: 10 | 2016-01-31 17:24:13
Removed historical data download ID 10 | 2016-01-31 17:24:13
Real-time Intraday chart data file updates started for NGH6-NYMEX | 2016-01-31 17:24:13
Intraday chart data file opened for NGH6-NYMEX | 2016-01-31 17:24:13
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:24:13
Intraday data recording state for symbol NGH6-NYMEX is set to download 'Pending'. | 2016-01-31 17:24:13
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:24:13
HD Request # 14 | Receiving Intraday data for 6BH6-CME starting at 2016-01-31 17:20:36 | 2016-01-31 17:24:13
HD Request # 14 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:44 | 2016-01-31 17:24:13
HD Request # 14 | Received 4 records from 2016-01-31 17:20:36 to 2016-01-31 17:24:00 (3.4 minutes) and wrote 3 records for 6BH6-CME | 2016-01-31 17:24:13
HD Request # 14 | Intraday download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 16 | 2016-01-31 17:24:13
Removed historical data download ID 16 | 2016-01-31 17:24:13
Real-time Intraday chart data file updates started for 6BH6-CME | 2016-01-31 17:24:13
Intraday chart data file opened for 6BH6-CME | 2016-01-31 17:24:13
HD Request # 16 | Downloading Intraday chart data for NGH6-NYMEX to the file NGH6-NYMEX.scid. Service: rim | 2016-01-31 17:24:13
HD Request # 16 | Download start Date-Time: 2016-01-31 17:23:03.000 | 2016-01-31 17:24:13
HD Request # 16 | Sending historical data request. Start Date-Time: 2016-01-31 17:23:03. Record interval: 0. Symbol: NGH6-NYMEX | 2016-01-31 17:24:13
HD Request # 17 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2016-01-31 17:24:13
HD Request # 17 | Download start Date-Time: 2016-01-31 17:23:18.000 | 2016-01-31 17:24:13
HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2016-01-31 17:24:13
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-01-31 17:24:13
Socket (10) | Connected. | 2016-01-31 17:24:13
HD Request # 17 | Sending historical data logon request message. | 2016-01-31 17:24:13
HD Request # 16 | Receiving Intraday data for NGH6-NYMEX starting at 2016-01-31 17:23:03 | 2016-01-31 17:24:13
HD Request # 16 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:28 | 2016-01-31 17:24:13
HD Request # 16 | Received 11 records from 2016-01-31 17:23:03 to 2016-01-31 17:23:57 (54.0 seconds) and wrote 3 records for NGH6-NYMEX | 2016-01-31 17:24:13
HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:23:18. Record interval: 0. Symbol: GBPUSD | 2016-01-31 17:24:13
HD Request # 16 | Intraday download COMPLETE for NGH6-NYMEX. Completion time: 0s. Unique request ID: 17 | 2016-01-31 17:24:13
Removed historical data download ID 17 | 2016-01-31 17:24:13
Chart #10 has tagged chart #9 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:13
HD Request # 17 | Decompressing data. | 2016-01-31 17:24:13
HD Request # 17 | Receiving Intraday data for GBPUSD starting at 2016-01-31 17:23:18 | 2016-01-31 17:24:13
HD Request # 17 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:31 | 2016-01-31 17:24:13
Socket (10) | Shutdown and closed. | 2016-01-31 17:24:13
The network socket for historical data has been closed. | 2016-01-31 17:24:13
HD Request # 17 | Received 101 records from 2016-01-31 17:23:18 to 2016-01-31 17:24:06 (48.0 seconds) and wrote 99 records for GBPUSD | 2016-01-31 17:24:13
Added 3 Time and Sales records to Intraday data file for GBPUSD after download. | 2016-01-31 17:24:13
HD Request # 17 | Intraday download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 12 | 2016-01-31 17:24:13
Removed historical data download ID 12 | 2016-01-31 17:24:13
Real-time Intraday chart data file updates started for GBPUSD | 2016-01-31 17:24:13
Intraday chart data file opened for GBPUSD | 2016-01-31 17:24:13
HD Request # 18 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2016-01-31 17:24:13
HD Request # 18 | Download start Date-Time: 2016-01-31 17:23:24.000 | 2016-01-31 17:24:13
HD Request # 18 | Using server: ds5.sierracharts.com port 10149 | 2016-01-31 17:24:13
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-01-31 17:24:13
Socket (11) | Connected. | 2016-01-31 17:24:13
HD Request # 18 | Sending historical data logon request message. | 2016-01-31 17:24:13
Chart #12 has tagged chart #11 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:13
HD Request # 18 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:23:24. Record interval: 0. Symbol: USDCAD | 2016-01-31 17:24:13
AUDJPY [M] 10 Sec #20 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:13
HD Request # 18 | Decompressing data. | 2016-01-31 17:24:13
HD Request # 18 | Receiving Intraday data for USDCAD starting at 2016-01-31 17:23:24 | 2016-01-31 17:24:13
HD Request # 18 | Timestamp of first Intraday data file record written: 2016-01-31 17:23:24 | 2016-01-31 17:24:13
Socket (11) | Shutdown and closed. | 2016-01-31 17:24:13
HD Request # 18 | Received 66 records from 2016-01-31 17:23:24 to 2016-01-31 17:24:03 (39.0 seconds) and wrote 64 records for USDCAD | 2016-01-31 17:24:14
Added 52 Time and Sales records to Intraday data file for USDCAD after download. | 2016-01-31 17:24:14
HD Request # 18 | Intraday download COMPLETE for USDCAD. Completion time: 1s. Unique request ID: 13 | 2016-01-31 17:24:14
Removed historical data download ID 13 | 2016-01-31 17:24:14
Real-time Intraday chart data file updates started for USDCAD | 2016-01-31 17:24:14
Intraday chart data file opened for USDCAD | 2016-01-31 17:24:14
6JH6-CME 16 PriceChanges #9 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:14
Chart #14 has tagged chart #13 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:14
Chart #14 has tagged chart #17 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:14
Chart #16 has tagged chart #15 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:14
GBPUSD [M] 100 PriceChanges #17 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:14
NQH6-CME 10 PriceChanges #11 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:15
6BH6-CME 5 PriceChanges #13 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:15
NGH6-NYMEX 10 PriceChanges #15 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:15
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:24:31
AUDJPY [M] 150 PriceChanges #1 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:24:31
Requesting symbol settings for rim. Overwrite = on. | 2016-01-31 17:24:56
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-31 17:24:56
HTTPS connection to www.sierrachart.com:443 (13) | Connected. | 2016-01-31 17:24:56
HTTPS connection to www.sierrachart.com:443 (13) | Starting TLS 1.2 connection. | 2016-01-31 17:24:56
HTTPS connection to www.sierrachart.com:443 (13) | SSL connection established. | 2016-01-31 17:24:56
Symbol settings received. | 2016-01-31 17:24:57
Processed received symbol settings | 2016-01-31 17:24:57
Reconnecting to the data feed after processing symbol settings. | 2016-01-31 17:24:57
Socket (5) | Shutdown and closed. | 2016-01-31 17:24:57
Socket (6) | Shutdown and closed. | 2016-01-31 17:24:57
SC DTC Data | Disconnected from the server. | 2016-01-31 17:24:57
Rithmic Trading | Disconnected. | 2016-01-31 17:24:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-31 17:24:57
Rithmic Trading | Port for executable: 65461 | 2016-01-31 17:24:59
Listening socket (952), port 65461 | Closed. | 2016-01-31 17:24:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-01-31 17:24:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 65461 | 2016-01-31 17:25:01
Socket (14) | Connected. | 2016-01-31 17:25:01
Rithmic Trading | Connected to server. | 2016-01-31 17:25:01
Rithmic Trading | Sending Encoding Request to server | 2016-01-31 17:25:01
Rithmic Trading | Setting DTC Encoding to Binary | 2016-01-31 17:25:01
Rithmic Trading | Sending logon request message. | 2016-01-31 17:25:01
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-01-31 17:25:01
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-01-31 17:25:01
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2016-01-31 17:25:01
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-01-31 17:25:02
HTTPS connection to www.sierrachart.com:443 (13) | SSL connection closed by remote side. | 2016-01-31 17:25:02
HTTPS connection to www.sierrachart.com:443 (13) | SSL object has been freed. SSL state is now disconnected. | 2016-01-31 17:25:02
HTTPS connection to www.sierrachart.com:443 (13) | Shutdown and closed. | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-01-31 17:25:02
Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-01-31 17:25:02
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-01-31 17:25:02
Rithmic Trading | Received logon response. | 2016-01-31 17:25:03
Rithmic Trading | Server Name: SC DTC Bridge. | 2016-01-31 17:25:03
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-01-31 17:25:03
Rithmic Trading | Successfully connected. IB='TopstepTrader'. | 2016-01-31 17:25:03
Rithmic Trading | Trading is supported. | 2016-01-31 17:25:03
Rithmic Trading | Order cancel and replace is supported. | 2016-01-31 17:25:03
Rithmic Trading | Connected to data and trading server. | 2016-01-31 17:25:03
Rithmic Trading | OCO Orders supported. | 2016-01-31 17:25:03
Rithmic Trading | Starting real-time market data updates for: NGH6-NYMEX. ID: 1 | 2016-01-31 17:25:03
Intraday data recording state for symbol NGH6-NYMEX is set to download 'Pending'. | 2016-01-31 17:25:03
HD Request # 19 | Downloading Intraday chart data for NGH6-NYMEX to the file NGH6-NYMEX.scid. Service: nymex | 2016-01-31 17:25:03
HD Request # 19 | Download start Date-Time: 2016-01-31 17:24:24.000 | 2016-01-31 17:25:03
HD Request # 19 | Error downloading historical Intraday data for NGH6-NYMEX. Not downloading Intraday data for symbol NGH6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:25:03
HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NGH6-NYMEX | 2016-01-31 17:25:03
HD Request # 19 | Intraday download COMPLETE for NGH6-NYMEX. Completion time: 0s. Unique request ID: 18 | 2016-01-31 17:25:03
Removed historical data download ID 18 | 2016-01-31 17:25:03
Real-time Intraday chart data file updates started for NGH6-NYMEX | 2016-01-31 17:25:03
Intraday chart data file opened for NGH6-NYMEX | 2016-01-31 17:25:03
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:25:03
HD Request # 20 | Downloading Intraday chart data for NGH6-NYMEX to the file NGH6-NYMEX.scid. Service: rim | 2016-01-31 17:25:03
HD Request # 20 | Download start Date-Time: 2016-01-31 17:24:24.000 | 2016-01-31 17:25:03
HD Request # 20 | Sending historical data request. Start Date-Time: 2016-01-31 17:24:24. Record interval: 0. Symbol: NGH6-NYMEX | 2016-01-31 17:25:03
Rithmic Trading | Starting real-time market data updates for: CLH6-NYMEX. ID: 2 | 2016-01-31 17:25:03
Intraday data recording state for symbol CLH6-NYMEX is set to download 'Pending'. | 2016-01-31 17:25:03
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:25:03
HD Request # 21 | Downloading Intraday chart data for CLH6-NYMEX to the file CLH6-NYMEX.scid. Service: nymex | 2016-01-31 17:25:03
HD Request # 21 | Download start Date-Time: 2016-01-31 17:24:50.000 | 2016-01-31 17:25:03
HD Request # 21 | Error downloading historical Intraday data for CLH6-NYMEX. Not downloading Intraday data for symbol CLH6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:25:03
HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLH6-NYMEX | 2016-01-31 17:25:03
HD Request # 21 | Intraday download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 20 | 2016-01-31 17:25:03
Removed historical data download ID 20 | 2016-01-31 17:25:03
Real-time Intraday chart data file updates started for CLH6-NYMEX | 2016-01-31 17:25:03
Intraday chart data file opened for CLH6-NYMEX | 2016-01-31 17:25:03
HD Request # 20 | Receiving Intraday data for NGH6-NYMEX starting at 2016-01-31 17:24:24 | 2016-01-31 17:25:03
HD Request # 20 | Received 1 record from 2016-01-31 17:24:24 to 2016-01-31 17:24:24 (0.0 seconds) and wrote 0 records for NGH6-NYMEX | 2016-01-31 17:25:03
HD Request # 20 | Intraday download COMPLETE for NGH6-NYMEX. Completion time: 0s. Unique request ID: 19 | 2016-01-31 17:25:03
Removed historical data download ID 19 | 2016-01-31 17:25:03
HD Request # 22 | Downloading Intraday chart data for CLH6-NYMEX to the file CLH6-NYMEX.scid. Service: rim | 2016-01-31 17:25:03
HD Request # 22 | Download start Date-Time: 2016-01-31 17:24:50.000 | 2016-01-31 17:25:03
HD Request # 22 | Sending historical data request. Start Date-Time: 2016-01-31 17:24:50. Record interval: 0. Symbol: CLH6-NYMEX | 2016-01-31 17:25:03
Rithmic Trading | Starting real-time market data updates for: NQH6-CME. ID: 3 | 2016-01-31 17:25:03
Intraday data recording state for symbol NQH6-CME is set to download 'Pending'. | 2016-01-31 17:25:03
HD Request # 23 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: cme | 2016-01-31 17:25:03
HD Request # 23 | Download start Date-Time: 2016-01-31 17:24:49.000 | 2016-01-31 17:25:03
HD Request # 23 | Error downloading historical Intraday data for NQH6-CME. Not downloading Intraday data for symbol NQH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:25:03
HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6-CME | 2016-01-31 17:25:03
HD Request # 23 | Intraday download COMPLETE for NQH6-CME. Completion time: 0s. Unique request ID: 22 | 2016-01-31 17:25:03
Removed historical data download ID 22 | 2016-01-31 17:25:03
Real-time Intraday chart data file updates started for NQH6-CME | 2016-01-31 17:25:03
Intraday chart data file opened for NQH6-CME | 2016-01-31 17:25:03
HD Request # 22 | Receiving Intraday data for CLH6-NYMEX starting at 2016-01-31 17:24:50 | 2016-01-31 17:25:03
HD Request # 22 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:52 | 2016-01-31 17:25:03
HD Request # 22 | Received 8 records from 2016-01-31 17:24:50 to 2016-01-31 17:24:53 (3.0 seconds) and wrote 5 records for CLH6-NYMEX | 2016-01-31 17:25:03
HD Request # 22 | Intraday download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 21 | 2016-01-31 17:25:03
Removed historical data download ID 21 | 2016-01-31 17:25:03
HD Request # 24 | Downloading Intraday chart data for NQH6-CME to the file NQH6-CME.scid. Service: rim | 2016-01-31 17:25:03
HD Request # 24 | Download start Date-Time: 2016-01-31 17:24:49.000 | 2016-01-31 17:25:03
HD Request # 24 | Sending historical data request. Start Date-Time: 2016-01-31 17:24:49. Record interval: 0. Symbol: NQH6-CME | 2016-01-31 17:25:03
Using Bid/Ask average for last trade price for GBPUSD | 2016-01-31 17:25:03
SC DTC Data | Starting real-time market data updates for: GBPUSD. ID: 4 | 2016-01-31 17:25:03
SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-01-31 17:25:03
Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2016-01-31 17:25:03
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-31 17:25:03
HD Request # 25 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2016-01-31 17:25:04
HD Request # 25 | Download start Date-Time: 2016-01-31 17:24:50.000 | 2016-01-31 17:25:04
HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2016-01-31 17:25:04
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-01-31 17:25:04
Socket (16) | Connected. | 2016-01-31 17:25:04
HD Request # 25 | Sending historical data logon request message. | 2016-01-31 17:25:04
Socket (15) | Connected. | 2016-01-31 17:25:04
SC DTC Data | Connected to server. | 2016-01-31 17:25:04
SC DTC Data | Sending Encoding Request to server | 2016-01-31 17:25:04
HD Request # 24 | Receiving Intraday data for NQH6-CME starting at 2016-01-31 17:24:49 | 2016-01-31 17:25:04
HD Request # 24 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:52 | 2016-01-31 17:25:04
HD Request # 24 | Received 6 records from 2016-01-31 17:24:49 to 2016-01-31 17:24:52 (3.0 seconds) and wrote 2 records for NQH6-CME | 2016-01-31 17:25:04
HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:50. Record interval: 0. Symbol: GBPUSD | 2016-01-31 17:25:04
HD Request # 25 | Decompressing data. | 2016-01-31 17:25:04
HD Request # 25 | Receiving Intraday data for GBPUSD starting at 2016-01-31 17:24:50 | 2016-01-31 17:25:04
HD Request # 25 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:52 | 2016-01-31 17:25:04
Socket (16) | Shutdown and closed. | 2016-01-31 17:25:04
The network socket for historical data has been closed. | 2016-01-31 17:25:04
HD Request # 24 | Intraday download COMPLETE for NQH6-CME. Completion time: 0s. Unique request ID: 23 | 2016-01-31 17:25:04
Removed historical data download ID 23 | 2016-01-31 17:25:04
Real-time Intraday chart data file updates started for NQH6-CME | 2016-01-31 17:25:04
Intraday chart data file opened for NQH6-CME | 2016-01-31 17:25:04
SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-01-31 17:25:04
SC DTC Data | Sending logon request message. | 2016-01-31 17:25:04
HD Request # 25 | Received 10 records from 2016-01-31 17:24:50 to 2016-01-31 17:24:54 (4.0 seconds) and wrote 7 records for GBPUSD | 2016-01-31 17:25:04
HD Request # 25 | Intraday download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 24 | 2016-01-31 17:25:04
Removed historical data download ID 24 | 2016-01-31 17:25:04
Real-time Intraday chart data file updates started for GBPUSD | 2016-01-31 17:25:04
Intraday chart data file opened for GBPUSD | 2016-01-31 17:25:04
Using Bid/Ask average for last trade price for USDCAD | 2016-01-31 17:25:04
SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 5 | 2016-01-31 17:25:04
Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2016-01-31 17:25:04
HD Request # 26 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2016-01-31 17:25:04
HD Request # 26 | Download start Date-Time: 2016-01-31 17:24:51.000 | 2016-01-31 17:25:04
HD Request # 26 | Using server: ds5.sierracharts.com port 10149 | 2016-01-31 17:25:04
SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 6 | 2016-01-31 17:25:04
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-01-31 17:25:04
Socket (17) | Connected. | 2016-01-31 17:25:04
HD Request # 26 | Sending historical data logon request message. | 2016-01-31 17:25:04
HD Request # 26 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:51. Record interval: 0. Symbol: USDCAD | 2016-01-31 17:25:04
HD Request # 26 | Decompressing data. | 2016-01-31 17:25:04
HD Request # 26 | Receiving Intraday data for USDCAD starting at 2016-01-31 17:24:51 | 2016-01-31 17:25:04
HD Request # 26 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:51 | 2016-01-31 17:25:04
Socket (17) | Shutdown and closed. | 2016-01-31 17:25:04
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-01-31 17:25:04
HD Request # 26 | Received 19 records from 2016-01-31 17:24:51 to 2016-01-31 17:24:56 (5.0 seconds) and wrote 18 records for USDCAD | 2016-01-31 17:25:04
HD Request # 26 | Intraday download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 25 | 2016-01-31 17:25:04
Removed historical data download ID 25 | 2016-01-31 17:25:04
Real-time Intraday chart data file updates started for USDCAD | 2016-01-31 17:25:04
Intraday chart data file opened for USDCAD | 2016-01-31 17:25:04
HD Request # 27 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-01-31 17:25:04
HD Request # 27 | Download start Date-Time: 2016-01-31 17:24:02.000 | 2016-01-31 17:25:04
HD Request # 27 | Using server: ds3.sierracharts.com port 10149 | 2016-01-31 17:25:04
SC DTC Data | Received logon response. | 2016-01-31 17:25:04
SC DTC Data | Server Name: SC Real-Time Server. | 2016-01-31 17:25:04
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-31 17:25:04
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-01-31 17:25:04
SC DTC Data | Successfully connected. | 2016-01-31 17:25:04
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-01-31 17:25:04
Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2016-01-31 17:25:04
Socket (18) | Connected. | 2016-01-31 17:25:04
HD Request # 27 | Sending historical data logon request message. | 2016-01-31 17:25:04
SC DTC Data | Restarting real-time data updates for symbol: GBPUSD | 2016-01-31 17:25:04
HD Request # 27 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:02. Record interval: 0. Symbol: AUDJPY | 2016-01-31 17:25:04
SC DTC Data | Restarting real-time data updates for symbol: USDCAD | 2016-01-31 17:25:04
HD Request # 27 | Decompressing data. | 2016-01-31 17:25:04
HD Request # 27 | Receiving Intraday data for AUDJPY starting at 2016-01-31 17:24:02 | 2016-01-31 17:25:04
HD Request # 27 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:07 | 2016-01-31 17:25:04
Socket (18) | Shutdown and closed. | 2016-01-31 17:25:04
HD Request # 27 | Received 132 records from 2016-01-31 17:24:02 to 2016-01-31 17:24:57 (55.0 seconds) and wrote 131 records for AUDJPY | 2016-01-31 17:25:04
HD Request # 27 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 26 | 2016-01-31 17:25:05
Removed historical data download ID 26 | 2016-01-31 17:25:05
Real-time Intraday chart data file updates started for AUDJPY | 2016-01-31 17:25:05
Intraday chart data file opened for AUDJPY | 2016-01-31 17:25:05
HD Request # 28 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2016-01-31 17:25:05
HD Request # 28 | Download start Date-Time: 2016-01-31 17:24:54.000 | 2016-01-31 17:25:05
HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2016-01-31 17:25:05
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-01-31 17:25:05
Chart #12 has tagged chart #11 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:05
Socket (19) | Connected. | 2016-01-31 17:25:05
HD Request # 28 | Sending historical data logon request message. | 2016-01-31 17:25:05
HD Request # 28 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:54. Record interval: 0. Symbol: GBPUSD | 2016-01-31 17:25:05
HD Request # 28 | Decompressing data. | 2016-01-31 17:25:05
HD Request # 28 | Receiving Intraday data for GBPUSD starting at 2016-01-31 17:24:54 | 2016-01-31 17:25:05
HD Request # 28 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:56 | 2016-01-31 17:25:05
Socket (19) | Shutdown and closed. | 2016-01-31 17:25:05
The network socket for historical data has been closed. | 2016-01-31 17:25:05
HD Request # 28 | Received 6 records from 2016-01-31 17:24:54 to 2016-01-31 17:24:57 (3.0 seconds) and wrote 4 records for GBPUSD | 2016-01-31 17:25:05
HD Request # 28 | Intraday download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 27 | 2016-01-31 17:25:05
Removed historical data download ID 27 | 2016-01-31 17:25:05
Real-time Intraday chart data file updates started for GBPUSD | 2016-01-31 17:25:05
Intraday chart data file opened for GBPUSD | 2016-01-31 17:25:05
HD Request # 29 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2016-01-31 17:25:05
HD Request # 29 | Download start Date-Time: 2016-01-31 17:24:56.000 | 2016-01-31 17:25:05
HD Request # 29 | Using server: ds5.sierracharts.com port 10149 | 2016-01-31 17:25:05
Rithmic Trading | Starting real-time market data updates for: 6BH6-CME. ID: 7 | 2016-01-31 17:25:05
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-01-31 17:25:05
Socket (20) | Connected. | 2016-01-31 17:25:05
HD Request # 29 | Sending historical data logon request message. | 2016-01-31 17:25:05
HD Request # 29 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:56. Record interval: 0. Symbol: USDCAD | 2016-01-31 17:25:05
HD Request # 29 | Decompressing data. | 2016-01-31 17:25:05
HD Request # 29 | Receiving Intraday data for USDCAD starting at 2016-01-31 17:24:56 | 2016-01-31 17:25:05
Socket (20) | Shutdown and closed. | 2016-01-31 17:25:05
Intraday data recording state for symbol 6BH6-CME is set to download 'Pending'. | 2016-01-31 17:25:05
HD Request # 29 | Received 1 record from 2016-01-31 17:24:56 to 2016-01-31 17:24:56 (0.0 seconds) and wrote 0 records for USDCAD | 2016-01-31 17:25:05
HD Request # 29 | Intraday download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 28 | 2016-01-31 17:25:05
Removed historical data download ID 28 | 2016-01-31 17:25:05
Real-time Intraday chart data file updates started for USDCAD | 2016-01-31 17:25:05
Intraday chart data file opened for USDCAD | 2016-01-31 17:25:05
HD Request # 30 | Downloading Intraday chart data for 6BH6-CME to the file 6BH6-CME.scid. Service: cme | 2016-01-31 17:25:05
HD Request # 30 | Download start Date-Time: 2016-01-31 17:24:24.000 | 2016-01-31 17:25:05
HD Request # 30 | Error downloading historical Intraday data for 6BH6-CME. Not downloading Intraday data for symbol 6BH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:25:05
HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BH6-CME | 2016-01-31 17:25:05
HD Request # 30 | Intraday download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 29 | 2016-01-31 17:25:05
Removed historical data download ID 29 | 2016-01-31 17:25:05
Real-time Intraday chart data file updates started for 6BH6-CME | 2016-01-31 17:25:05
Intraday chart data file opened for 6BH6-CME | 2016-01-31 17:25:05
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:25:05
HD Request # 31 | Downloading Intraday chart data for 6BH6-CME to the file 6BH6-CME.scid. Service: rim | 2016-01-31 17:25:05
HD Request # 31 | Download start Date-Time: 2016-01-31 17:24:24.000 | 2016-01-31 17:25:05
HD Request # 31 | Sending historical data request. Start Date-Time: 2016-01-31 17:24:24. Record interval: 0. Symbol: 6BH6-CME | 2016-01-31 17:25:05
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:25:05
Rithmic Trading | Starting real-time market data updates for: 6JH6-CME. ID: 8 | 2016-01-31 17:25:05
Intraday data recording state for symbol 6JH6-CME is set to download 'Pending'. | 2016-01-31 17:25:05
HD Request # 32 | Downloading Intraday chart data for 6JH6-CME to the file 6JH6-CME.scid. Service: cme | 2016-01-31 17:25:05
HD Request # 32 | Download start Date-Time: 2016-01-31 17:24:50.000 | 2016-01-31 17:25:05
HD Request # 32 | Error downloading historical Intraday data for 6JH6-CME. Not downloading Intraday data for symbol 6JH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:25:05
HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6JH6-CME | 2016-01-31 17:25:05
HD Request # 32 | Intraday download COMPLETE for 6JH6-CME. Completion time: 0s. Unique request ID: 31 | 2016-01-31 17:25:05
Removed historical data download ID 31 | 2016-01-31 17:25:05
Real-time Intraday chart data file updates started for 6JH6-CME | 2016-01-31 17:25:05
Intraday chart data file opened for 6JH6-CME | 2016-01-31 17:25:05
HD Request # 31 | Receiving Intraday data for 6BH6-CME starting at 2016-01-31 17:24:24 | 2016-01-31 17:25:05
HD Request # 31 | Received 1 record from 2016-01-31 17:24:24 to 2016-01-31 17:24:24 (0.0 seconds) and wrote 0 records for 6BH6-CME | 2016-01-31 17:25:05
HD Request # 31 | Intraday download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 30 | 2016-01-31 17:25:05
Removed historical data download ID 30 | 2016-01-31 17:25:05
HD Request # 33 | Downloading Intraday chart data for 6JH6-CME to the file 6JH6-CME.scid. Service: rim | 2016-01-31 17:25:05
HD Request # 33 | Download start Date-Time: 2016-01-31 17:24:50.000 | 2016-01-31 17:25:05
HD Request # 33 | Sending historical data request. Start Date-Time: 2016-01-31 17:24:50. Record interval: 0. Symbol: 6JH6-CME | 2016-01-31 17:25:05
HD Request # 33 | Receiving Intraday data for 6JH6-CME starting at 2016-01-31 17:24:50 | 2016-01-31 17:25:05
HD Request # 33 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:56 | 2016-01-31 17:25:05
HD Request # 33 | Received 2 records from 2016-01-31 17:24:50 to 2016-01-31 17:24:56 (6.0 seconds) and wrote 1 record for 6JH6-CME | 2016-01-31 17:25:05
HD Request # 33 | Intraday download COMPLETE for 6JH6-CME. Completion time: 0s. Unique request ID: 32 | 2016-01-31 17:25:05
Removed historical data download ID 32 | 2016-01-31 17:25:05
Chart #14 has tagged chart #13 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:05
Chart #14 has tagged chart #17 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:05
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:05
Rithmic Trading | Starting real-time market data updates for: 6EH6-CME. ID: 9 | 2016-01-31 17:25:06
Intraday data recording state for symbol 6EH6-CME is set to download 'Pending'. | 2016-01-31 17:25:06
HD Request # 34 | Downloading Intraday chart data for 6EH6-CME to the file 6EH6-CME.scid. Service: cme | 2016-01-31 17:25:06
HD Request # 34 | Download start Date-Time: 2016-01-31 17:24:32.000 | 2016-01-31 17:25:06
HD Request # 34 | Error downloading historical Intraday data for 6EH6-CME. Not downloading Intraday data for symbol 6EH6-CME. Less than 10 minutes since last record Date-Time. | 2016-01-31 17:25:06
HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH6-CME | 2016-01-31 17:25:06
HD Request # 34 | Intraday download COMPLETE for 6EH6-CME. Completion time: 0s. Unique request ID: 33 | 2016-01-31 17:25:06
Removed historical data download ID 33 | 2016-01-31 17:25:06
Real-time Intraday chart data file updates started for 6EH6-CME | 2016-01-31 17:25:06
Intraday chart data file opened for 6EH6-CME | 2016-01-31 17:25:06
Rithmic Trading | Using primary service for historical data. | 2016-01-31 17:25:06
HD Request # 35 | Downloading Intraday chart data for 6EH6-CME to the file 6EH6-CME.scid. Service: rim | 2016-01-31 17:25:06
HD Request # 35 | Download start Date-Time: 2016-01-31 17:24:32.000 | 2016-01-31 17:25:06
HD Request # 35 | Sending historical data request. Start Date-Time: 2016-01-31 17:24:32. Record interval: 0. Symbol: 6EH6-CME | 2016-01-31 17:25:06
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-01-31 17:25:06
Chart #10 has tagged chart #9 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
Using Bid/Ask average for last trade price for EURUSD | 2016-01-31 17:25:06
SC DTC Data | Starting real-time market data updates for: EURUSD. ID: 10 | 2016-01-31 17:25:06
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2016-01-31 17:25:06
HD Request # 36 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2016-01-31 17:25:06
HD Request # 36 | Download start Date-Time: 2016-01-31 17:24:50.000 | 2016-01-31 17:25:06
HD Request # 36 | Using server: ds3.sierracharts.com port 10149 | 2016-01-31 17:25:06
HD Request # 35 | Receiving Intraday data for 6EH6-CME starting at 2016-01-31 17:24:32 | 2016-01-31 17:25:06
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-31 17:25:06
HD Request # 35 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:52 | 2016-01-31 17:25:06
HD Request # 35 | Received 2 records from 2016-01-31 17:24:32 to 2016-01-31 17:24:52 (20.0 seconds) and wrote 1 record for 6EH6-CME | 2016-01-31 17:25:06
HD Request # 35 | Intraday download COMPLETE for 6EH6-CME. Completion time: 0s. Unique request ID: 34 | 2016-01-31 17:25:06
Removed historical data download ID 34 | 2016-01-31 17:25:06
Socket (21) | Connected. | 2016-01-31 17:25:06
HD Request # 36 | Sending historical data logon request message. | 2016-01-31 17:25:06
Chart #16 has tagged chart #15 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
Chart #7 has tagged chart #8 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
HD Request # 36 | Requesting Intraday data. Start Date-Time: 2016-01-31 17:24:50. Record interval: 0. Symbol: EURUSD | 2016-01-31 17:25:06
NQH6-CME 10 PriceChanges #11 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
HD Request # 36 | Decompressing data. | 2016-01-31 17:25:06
HD Request # 36 | Receiving Intraday data for EURUSD starting at 2016-01-31 17:24:50 | 2016-01-31 17:25:06
HD Request # 36 | Timestamp of first Intraday data file record written: 2016-01-31 17:24:52 | 2016-01-31 17:25:06
Socket (21) | Shutdown and closed. | 2016-01-31 17:25:06
The network socket for historical data has been closed. | 2016-01-31 17:25:06
HD Request # 36 | Received 46 records from 2016-01-31 17:24:50 to 2016-01-31 17:24:58 (8.0 seconds) and wrote 45 records for EURUSD | 2016-01-31 17:25:06
HD Request # 36 | Intraday download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 35 | 2016-01-31 17:25:06
Removed historical data download ID 35 | 2016-01-31 17:25:06
Real-time Intraday chart data file updates started for EURUSD | 2016-01-31 17:25:06
Intraday chart data file opened for EURUSD | 2016-01-31 17:25:06
GBPUSD [M] 100 PriceChanges #17 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
Chart #21 has tagged chart #20 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
CLH6-NYMEX 10 PriceChanges #8 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:06
6BH6-CME 5 PriceChanges #13 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:07
AUDJPY [M] 10 Sec #20 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:07
6JH6-CME 16 PriceChanges #9 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:08
AUDJPY [M] 150 PriceChanges #1 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:08
NGH6-NYMEX 10 PriceChanges #15 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:08
Chart #3 has tagged chart #4 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:08
6EH6-CME 16 PriceChanges #4 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:08
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:25:08
EURUSD [M] 150 PriceChanges #5 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:25:09
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:26:24
EURUSD [M] 150 PriceChanges #5 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:26:24
AUDJPY [M] 10 Sec #20 | Reloading chart. | 2016-01-31 17:26:35
AUDJPY [M] Renko 23-22-21-x #21 | Reloading chart. | 2016-01-31 17:28:17
Chart #21 has tagged chart #20 for full recalculation. Chartbook: Chartbook31.cht | 2016-01-31 17:28:25
AUDJPY [M] 10 Sec #20 | Performing a full recalculation because it has been tagged. Chartbook: Chartbook31.cht | 2016-01-31 17:28:25
AUDJPY [M] 10 Sec #20 | Reloading chart. | 2016-01-31 17:29:39
Date Time Of Last Edit: 2016-02-01 01:06:53
[2016-02-01 05:28:22]
We do not see any problem based on the information the Message Log.
There is no error returned from the market data request:
Therefore, refer to help topic 3.4:
http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4
Are you receiving real-time data from the data feed according to the test procedure given?
Date Time Of Last Edit: 2016-02-01 05:28:47
