Date/Time: Sat, 18 May 2024 03:52:16 +0000
color moving average based on alert condition?
View Count: 1548
[2016-01-30 00:31:00] |
User380760 - Posts: 88 |
How to color moving average based on alert condition? I tried "color bar", doesn't seem to apply to the moving average. Thanks. |
[2016-01-31 19:18:23] |
up
[2016-01-31 21:20:39] |
Sawtooth - Posts: 4000 |
Try this: -Set the Based On to the MA study -Set the Output When Condition True to Use Input Data -Set the Input Data to Avg |
[2016-01-31 21:39:30] |
the price bar color changed, but not the color of moving average. Can I custom the color of moving average based on alert condition?
[2016-01-31 23:01:52] |
You also must change the Draw Style to Line, or Line - SkipZeros. There are other caveats when coloring a line from a formula, the solutions to which depend on specifically what you are doing. For an example solution to a certain line coloring issue, see this: http://www.sawtoothtrade.com/free-stuff-13.html |
[2016-01-31 23:43:46] |
It works! Thank you very much, tomgilb. You have been very helpful to all of us.
[2016-02-01 02:05:57] |
Step-by-step procedures for how to do this have always been documented here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
