Date/Time: Sun, 05 May 2024 20:08:33 +0000
How to display ATR as a value, and not a line
View Count: 2879
[2013-06-27 11:00:00] |
User79401 - Posts: 7 |
I would like to have the ATR(n) where n is number of bars displayed as a value on my chart in a textbox or something instead of drawing a line. Is this achievable somehow?
[2013-06-27 13:20:02] |
M5amhan - Posts: 468 |
put it in whatever region you would like and have your settings like this (attached) it also shows up in the values windows this way, this is how i use it |
[2013-06-27 13:57:33] |
ganz - Posts: 1048 |
User79401 hi try F6 -> Text Display for Study gd lck |
[2013-07-04 19:53:00] |
Thanks ganz's solution did the job. http://www.sierrachart.com/image.php?l=137296756766.png |
[2013-07-09 15:18:47] |
JP - Posts: 24 |
Thank you! User79401, how were you able to put the ATR text display in/next to the chart header? I tried but the highest I can put mine is below the chart header. Date Time Of Last Edit: 2013-07-09 15:23:39
