Date/Time: Sun, 28 Apr 2024 23:25:57 +0000
SP&500 historical chart
View Count: 1343
[2013-06-27 03:17:37] |
martintokman - Posts: 7 |
Hi, i would like to know if i can create a historical chart for SP&500 from 1983 to now. I am actually using ES# for viewing the chart but it only shows me data from 2003 to now. Kind regards, |
[2013-06-28 01:35:24] |
We apologize for the delay. You can do this. Select File >> Find Symbol and in the Selected Symbol box type $INX Press the Open Historical Chart button. The data will go back to 1980. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-28 01:35:43
