Date/Time: Mon, 29 Apr 2024 11:39:37 +0000
Color box in Zig Zag study not activated
View Count: 1838
[2013-06-26 23:44:19] |
MMX - Posts: 119 |
At my request, on 6-21-13, you agreed to add a second color box to the 3rd line in the subgraph section of the Zig Zag study, which you did and it was included in v991. However, only the color box on the left is working, the color box on the right is not being recognized, it's not working. I can't mention the name of that third line because it's an automatic trigger for turning this thread (for the third time) into a user discussion thread.
[2013-06-27 06:13:24] |
We apologize. We are under a very heavy workload right now and it's just not easy for us to be handling any new requests. How are the 2 colors meant to color the Subgraph? So when we flag something as a User Discussion, it is because it is not within the domain of what we view as necessary support or requests that require our attention. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-27 06:13:52
[2013-06-27 15:01:54] |
MMX - Posts: 119 |
They color the up bars and the down bars of the Weis Wave (a $500 plug-in that Sierra Charts provides for free to all it's users). When analyzing the Weis Wave you're always comparing the current wave (say it's an upwave) to all the previous upwaves, and when all the waves are the same color it becomes tedious trying to figure out if that 8th wave back is a down wave or an up wave. Using 2 colors makes everything very obvious. The 3rd line in the Zig Zag subgraphs section is normally not there, but when the "Calculate ZigZag Volume" in the Settings And Input tab is changed from No to Yes (once selected, you have to close the dialog box for the Yes to take affect), then the 3rd line will show up in the subgraphs section, it's called A..........V.....
[2013-06-28 08:52:23] |
OK, we understand. We will work on this.
