Date/Time: Sat, 18 May 2024 22:27:24 +0000
Trying To Use 2 Computers With AMP Account
View Count: 534
[2016-01-24 19:53:40] |
User417726 - Posts: 9 |
Hello, I am trying to use 2 computers (workdesk and laptop), I can login fine with the workdesk but having trouble with the laptop. I get the message that I have to contact Sierra Chart for support. Is there anything you can do to allow my account 2 monitors? Thanks |
[2016-01-24 20:17:27] |
You need a direct account to use Sierra Chart on 2 systems at a time: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
