Date/Time: Sat, 18 May 2024 19:29:41 +0000
"Waiting to Reconnect" for OEC
View Count: 1080
[2016-01-24 18:34:37] |
User343010 - Posts: 2 |
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-01-24 10:31:14 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222 | 2016-01-24 10:31:14 GainCapital FIX Trading socket (43) | Connected. | 2016-01-24 10:31:14 GainCapital FIX Trading socket (43) | Starting TLS 1.2 connection. | 2016-01-24 10:31:14 GainCapital FIX Trading socket (43) | SSL connection established. | 2016-01-24 10:31:15 GainCapital FIX Trading: Sending the Logon message. | 2016-01-24 10:31:15 GainCapital FIX Trading: Received a Logout message. | 2016-01-24 10:31:15 GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-01-24 10:31:15 GainCapital FIX Trading socket (43) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-24 10:31:15 GainCapital FIX Trading socket (43) | SSL has been shut down. | 2016-01-24 10:31:15 GainCapital FIX Trading socket (43) | SSL object has been freed. SSL state is now disconnected. | 2016-01-24 10:31:15 GainCapital FIX Trading socket (43) | Shutdown and closed. | 2016-01-24 10:31:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-24 10:31:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-24 10:31:15 GAIN Capital/OEC | Disconnected from the trading server. | 2016-01-24 10:31:15 GAIN Capital/OEC | Disconnected. | 2016-01-24 10:31:15 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-24 10:31:15 Thanks |
[2016-01-24 20:16:12] |
Refer to: http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ServerAvailability Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
